Sign in to follow this
Followers 0
prairiestr
LG dishwasher LDS5811ST/02
4 posts in this topic
in normal cycle does not seem to heat water, is this normal?
how is the element replaced?
does pump come out thru the top? (inside cavity)
service manual?
<<<in normal cycle does not seem to heat water, is this normal?>>>
The LG 5811 dishwasher uses the Heating Element---only during *Main Wash* and *Final Rinse*.
In the *Normal Cycle*---the Main Wash occurs around the middle of the cycle---and the Final Rinse at the end of the cycle.
The Heating Element is not used at any other time during the entire cycle.
Other Things To Consider...
All LG 5811 dishwashers have the not-so-good Sump Assy (6871DD1002B)
Nearly all fail with symptoms ranging from:
Noisy During Wash
Poor Wash Performance
Intermittent/Permanent "LE" error
If the Sump Assy has not been replaced/upgraded---that's where I'd start (AJH31248604)
Also...
Verify that the customer has a standard Water Heater.
Tankless Water Heaters are always a problem for LG (and doubtless many other brands) dishwashers---as far as Cleaning Effectiveness/Consistency.
Reg and john63,
Outstanding info.! This will help a lot.
Additional symptom of this machine is a high pitched squeal occasionally in wash cycle, I heard it when the kick plate and insulation was removed.
Sump sounds like the culprit here.
Thanks for the help. :thanks:
Followers 0
