Sign in to follow this
Followers 0
tommytech
lg washer modelwm1832cw
7 posts in this topic
hey guys.trying to diagnose a friends washer over the phone.they get an le fault code,but washer door locks,agitates both directions ,but clock doesnt count down past 17 in quick wash before le code is displayed,also does not drain,but drain pump is not jammed. could a bad pump give that code?
 <<<could a bad pump give that code?>>>
No.
A failed Drain Motor would trigger an error of "OE".
Replace the HALL EFFECT SENSOR (6501KW2002A) and the MOTOR HARNESS (6877ER1016B)
thanks guys,its a long drive over there,good to have the parts i need the first trip.parts purchased thru this site by customer
heading out for this repair today,any special tools or techniques required?
10mm and 17mm sockets.
thank you for the replies,fixed the problem. Cheers!
Followers 0
