Maytag bravos washer not completing cycles
4 replies to this topic
#1 Mratjamerson
Mratjamerson
  • 6 posts
Posted 17 September 2013 - 10:16 AM
Maytag bravos MVWX500XW1. I have replaced control board and shift actuator. Tested on quick wash and works fine. Also filled with water, drain and spin works fine. No error codes. Belt and motor check out fine. Customer says the cycle is still not spinning water out of clothes.
#2 Thirstytech
Thirstytech
    Kohai
  • Master Appliantologist
  • 464 posts
  • Flavorite Brew:Greenbush Starchicken Shotgun
Posted 19 September 2013 - 07:39 PM
Welcome!  Will it go through either the manual or automatic diagnostic modes?
Nearly every house in the USA has at least 4 major appliances that will need repair, learn how this can work to your advantage -> http://www.mastersam...iliate.php?id=6
#3 JJ Surfer
JJ Surfer
    Sōhei
  • Appliantologist
  • 154 posts
  • Flavorite Brew:Sierra Nevada pale ale
Posted 20 September 2013 - 04:10 AM
Just double checking...no stored error codes?
#4 JJ Surfer
JJ Surfer
    Sōhei
  • Appliantologist
  • 154 posts
Posted 20 September 2013 - 04:15 AM
We're there any error codes before board and shifter were changed?
#5 Thirstytech
Thirstytech
    Kohai
  • 464 posts
Posted 20 September 2013 - 01:00 PM
So, is the complaint that it's not completing the cycle or is it that the clothes are still too wet/not spun out all the way when the customer removes them?
If you can get the machine to successfully go through all the spin tests in the manual diagnostic mode then you may have a "use and care" issue with the customer.  Unbalanced load, overloaded,  too much detergent, incorrect cycle, etc.
Find out what they are washing when this happens and what cycle they are using.  Have them load the machine for you and see what they are doing.
