Bosch Dishwasher shu6800
7 replies to this topic
#1 KCTBURY
KCTBURY
    www.ieappliance.com
  • Chief Appliantologist
  • 108 posts
  • Flavorite Brew:Coke
Posted 18 September 2013 - 11:32 PM
Working on a Bosch Dishwasher.
Model Number SHU6800
When you press the power on button the dishwasher starts to run with 13 min on the timer.
The Timer counts down and nothing happens except the circulation motor runs.
None of the buttons will work on the panel
The motor runs but the water is not being moved.
My first instinct is the circulation motor but why does it all ways start with 13 min?
Doesn't drain or anything!
Can not get into test mode either
#2 jumptrout
jumptrout
  • 1,380 posts
  • Flavorite Brew:Coors Light
Posted 19 September 2013 - 06:01 AM
Are you sure the circulation motor is running and not the drain pump?
If circ motor and no water moving could be a sump blockage or bad impeller.
If drain motor could be bad impeller or blocked drain outlet.
Disconnect then reconnect all control board wires.
Check for water in the base pan.
    Shōgun
  • Master Samurai Tech
  • 30,062 posts
Posted 19 September 2013 - 08:02 AM
Post the complete model number.
#4 KCTBURY
KCTBURY
    www.ieappliance.com
  • 108 posts
Posted 19 September 2013 - 07:19 PM
Model Number can not be made out  that is the model number off the owners manual.
#5 Budget Appliance Repair
  • 4,933 posts
Posted 20 September 2013 - 06:16 AM
Sometimes Bosch has a second mod/ser# sticker on the back side of the kickplate.
Who's great idea at Bosch was it to put the mod/ser# sticker right on the door and use those stupid printed labels that all the wording rubs off of so easily?
William Burk (Willie)
Eureka, CA 95501
#6 PDuff
PDuff
  • 2,017 posts
Posted 20 September 2013 - 12:34 PM
Probably an SHU6806UC/**.  I expect a "double whammy".  Drain pump running due to leak at circulating motor coupled with a kinked drain hose.  Feel inside the base for standing water as Brother jumptrout advised and pull the unit to inspect the corrugated drain hose.
#7 KCTBURY
KCTBURY
    www.ieappliance.com
  • 108 posts
Posted 20 September 2013 - 05:52 PM
Will do, Going to see it again on Monday, Thanks for the help.
#8 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,467 posts
  • Flavorite Brew:What's on tap?
Posted 21 September 2013 - 09:13 AM
 Could be a shocking experience if fingers touch fill valve wires whilst probing for water in base (lesson learned)... :woot:
Mother Teresa
The views and opinions expressed in this post are those of the author and do not necessarily reflect or represent the views and opinions held by my employer. All data and information provided is for informational purposes only.
Big Brother
