jackie
ge refrig problem
4 posts in this topic
have a ge model no. gsl25jfpabs.   nothing is cooling...evap and condenser fans running....compressor is not....is cool to touch, no noise or vibration.  is it the motherboard that is faulty?...checked start relay, does not rattle....and seems there is no voltage to compressor....is mother board most likely cause?
thanks in advance
thanks in advance
also could it be one of the thermistors bad
If the Fans are running, the Thermistors are telling the MotherBoard the Fridge needs Cooling
http://www.repairclinic.com/referral.asp?R=154&N=1531075
Main-Control-Board-WR55X10942-01091474.j
Jump between J8 and J11 on the blue 3 terminal plug on motherboard, if compressor runs, bad board.
Edited by richseattle56
