rdfloyd
LG WM2277HM - Bad Bearing?
11 posts in this topic
I bought a 2-3 year old LG WM2277HM front load washer about 1 year ago.  It's a decent washer, but rather unreliable.
My latest problem is a sound coming from the back of the drum.  I can only guess that the bearing is bad, but I've never heard a bearing make that sound before.  I recorded a video to try and help describe the issue (around 0:08 is the clearest audio): http://www.youtube.com/watch?v=wTA_cj67OrM
The pulsing "plastic" noise is what I think the problem is.  When running at high speed during the spin cycle, I can hear it from across the house (40-50 yards), and can smell burning plastic.
I've gone through the service manual and done all of the related troubleshooting steps.  There is nothing caught between the drum and housing.  The only thing I haven't done is inspected stator and rotor assembly for any contact issues (friction causing the burning smell).
I've read online that if it is the bearing, the machine is as good as trash, since replacing it is not worth the cost of labor/parts.  Sears has a service contract for $300 that will cover the machine fully for one year.  Does anyone think that it's worth the extra investment?
What is the SERIAL NUMBER ?
 S/N: 503KW07267
http://i.imgur.com/WAoCIpc.jpg
In addition, for now I've found a cheap washer that I am getting tomorrow.  So reaching a quick solution isn't necessary, and I'm willing to take my time to fix the machine.
Thanks for the help!
I'm not sure how to edit posts, but I forgot to mention an important detail.
A few days before the noise issue, I noticed that the washing machine was more prone to being out of balance, even though the unit was firmly touching all four corners of the tile floor.  A couple of times I had to stop it mid-spin and take out about half of the load (even though it wasn't overloaded to begin with).
<<<S/N: 503KW07267>>>
Built March 2005
Parts list coming shortly:)
Built March 2005
Well that's significantly older than I was told.  Thank you very much for helping.  I can't express my gratitude enough!
<<<The pulsing "plastic" noise is what I think the problem is. When running at high speed during the spin cycle, I can hear it from across the house (40-50 yards), and can smell burning plastic.>>>
Usually a symptom of---a cracked/broken *tub support*---which is part of the stainless steel INNER DRUM.
If the washer is being used---in spite of the noise/racket---eventually the FRONT TUB COVER will be damaged beyond repair. In some cases---the DOOR GASKET will also be destroyed.
This will cause an odor of burning plastic and rubber.
Front load washer tub assemblies consist of:
1) An INNER DRUM
2) REAR TUB (half shell---which also has bearings)
3) FRONT TUB COVER
Parts needed:
1) INNER BEARING (4280FR4048L)
2) OUTER BEARING (4280FR4048E)
3) BEARING SEAL (4036ER2004A)
4) TUB O-RING (4036ER4001B)
5) INNER DRUM (3045ER1006E)
Possibly may need a new FRONT TUB COVER...
6) FRONT TUB COVER (3550ER0004F)
Other parts/components that *ought* to be replaced if doing this level of work...
1) HALL EFFECT SENSOR/Rotor Position Sensor (6501KW2002A)
2) MOTOR WIRE HARNESS (6877ER1016B)
3) DRAIN MOTOR (4681EA2001T)
I'm fairly proficient when it comes to machinery.  However, should I let the professionals handle this one?  It sounds rather involved, since I assume I have to disassemble the entire drum assembly.  Is there a manual that explains the process in detail (with required tools, etc.)?
Right now, I'm thinking it's best that I go ahead and buy the Sears maintenance plan.  The parts alone will cost more than that, so it seems like a good deal to get the washer covered.  Thoughts?
Buy the maintenance
It has to be *your* decision...
SEARS PLAN:
$300.00
Possible 2 to 4 weeks until completion-of-work
Plan *only* covers repair/replacement of failed components (no preventive actions)
Easiest course to take (NO WORK REQ'D)
DIY METHOD:
Lots of work req'd
Parts (from repair clinic) potential total of around $390
Did I mention *lots* of work ? :)
the plan sears is selling you only covers repairs up to 500$,   parts and labor, that job will probably quote more then that with sears pricing
