Magenta#90
Whirpool duet washer GHW9150PW3 "f11 and DL code
4 posts in this topic
I replaced the CCU relay's (3) for the F11 code, but still not responding, won't rotate now i'm getting "DL" code, how to test the MCU, this test was uploaded by Samurai on May 07,2013, I cannot locate. I disconnected the BLUE wire harness and try to start the machine seems to start but is not because the connector is off, doe means that the MCU is bad??? HElp.
It is in the appliantology gallery under washer repair; testing mcu in a whirlpool duet washer.
Yes, what you are seeing means you have a bad mcu according to the gallery post.
Went back replaced MCU now is running, bad news the spider in the back is loose, so it may take couple of months before all come loose and she have to buy another F/l washer.
