jdfelsch
Kenmore HE2t Model# 11047566602 gets absolutely no power
2 posts in this topic
So my Washing machine won't turn on.  I've checked the power outlet and it's fine.
When I plug in my washing machine I do not hear a "click", and I've read that the CCU needs to be replaced.  I haven't opened up the washer yet to do more diagnostics.  I am going to do that today.  I am hoping i just find a bad switch or blown fuse some where.
Any help on what I should be looking for would be helpful.  Schematics , electronics diagnostic procedures, etc...
Don't have the money for a service call.  Let me know if you can help thanks.
This is the link to the electronic control unit on the washer.  Not quite sure which part is the CCU.  It's either number 3 or number 6.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11047566602/0582/0153200/K0712023/00003?blt=06&prst=0&shdMod=11047566602
1. Check that the unit is plugged into a working outlet and for blown fuses.
2. Verify that the plug doesn’t have two adapters attached to it.
3. Unplug washer or disconnect power.
4. Disconnect green connector (IF2) from the CCU.
5. Plug in washer or reconnect power.
6. Check that there is voltage of 120v at the CCU terminals (IF2).
7. If no voltage is observed, unplug washer or disconnect power.
8. Check that the connections of the power cord to the line filter
(white-neutral / black-line) and to the CCU (IF2) are not broken or with wires detached.
9. Check continuity from the RFI filter connector to the CCU (IF2 cavity connector).
http://www.repairclinic.com/referral.asp?R=154&N=2311329
http://www.repairclinic.com/referral.asp?R=154&N=1201248
