Dryer, can't figure out model number!
13 replies to this topic
#1 DTJango
DTJango
  • 14 posts
  • Flavorite Brew:Irish Death
Posted 22 September 2013 - 10:33 PM
Hello,
I previously came for help with my washer, and I appreciate it greatly. I managed to find what was wrong and I'm so happy for that.
Now my dryer is giving me trouble. I think I know what it is, but even if I did, I cannot figure out the model. The sticker seems to have worn away, making it impossible to read.
Here are some images, hopefully someone will be able to piece them together to help identify what it is.
The sticker, or what's left of it:
Front of the dryer, which I hope is unique enough that it's all that's needed to be seen to identify, as unlikely as that is:
The wiring diagram in the documentation found on the inside:
The envelope found inside, that held the documentation:
That number just gives me parts for a small engine of something on RepairClinic...
So, any help would be welcome. I thank you in advance.
#2 DTJango
DTJango
  • 14 posts
Posted 22 September 2013 - 10:44 PM
Ugh, it's late and I'm frustrated...so I am so sorry for not including that it's a Frigidaire front-loading dryer in the topic title. If there's any way I can change that, or if I should just resubmit, please let me know. It's poor forum etiquette for this type of topic, and I apologize.
#3 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 22 September 2013 - 10:56 PM
I'm searching ..
in the mean time ... what's wrong with the Washer ?
#4 DTJango
DTJango
  • 14 posts
Posted 22 September 2013 - 11:06 PM
Pretty sure it's the door lock assembly, at least based off everything I could find and figure out. I could be totally wrong, too, since I'm no expert, but the pump was fine and so was the control board, at least from the tests recommended both here and in the tech sheet.
#5 RegUS_PatOff
  • 33,588 posts
Posted 22 September 2013 - 11:10 PM
are there flashing lights for the error code ?
#6 DTJango
DTJango
  • 14 posts
Posted 22 September 2013 - 11:22 PM
For the dryer? Or do you mean flashing for the error code for the door lock for the washer?
If for the dryer, yes, and it's just for E68, stuck button. When I go into the mode to check multiple errors, there are two others, E25 and E5B. No matter what the problem is when I can get to testing, I still need the model and would like to take a look at rough cost estimates while I can.
I found FEQ1442ES to appear to be exact based on exterior looks, though when I find the data sheet for it, the numbers in the bottom right corner are different. The one on mine is: 134509400C 0606
#7 RegUS_PatOff
  • 33,588 posts
Posted 22 September 2013 - 11:39 PM
I'm sorry , Dryer ..
whats the part number on the wiring diagram ?
#8 DTJango
DTJango
  • 14 posts
Posted 22 September 2013 - 11:46 PM
I thought I posted this in my images above. Guess not: XJWZ9Qo.jpg
#9 RegUS_PatOff
  • 33,588 posts
Posted 23 September 2013 - 12:42 AM
electric Dryer could be FEQ1442E
gas Dryer could be FGQ1442E
the first picture with model number is too blurry to see anything
#10 DTJango
DTJango
  • 14 posts
Posted 23 September 2013 - 12:45 AM
The first picture has no model number. It has the letters "MODE" and you can faintly see bits and pieces of a line for numbers and letters, but can't make any of them out. It's basically blank. Even the serial number just has "SER". Roughly 98% of the sticker is faded to white.
#11 DTJango
DTJango
  • 14 posts
Posted 23 September 2013 - 12:58 AM
The tech sheet for both FEQ1442ES and FEQ1442E have the same wiring diagram part no. 134509400, while the one from in my dryer has 134509400 C. Both are the same, except for the C at the end of the one for mine.
Does this mean I could get the same parts for either of those, or does the "C" ruin everything?
#12 RegUS_PatOff
  • 33,588 posts
Posted 23 September 2013 - 09:52 AM
I think the rev "C" just means there's a revision to the wiring diagram
may have fixed an error in the diagram, or added some info
The models that have the same wiring diagram, the parts may work electrically,
but some parts may or may not fit mechanically.
#13 DTJango
DTJango
  • 14 posts
Posted 23 September 2013 - 11:55 AM
Would there maybe be a part number on the part itself? Say if it's the control board, would I find a number for the control board on the component itself that can be used to find a replacement?
Or, at the very least, could I try finding parts from the other models mentioned and check the dimensions to compare to what's in my dryer to see if they would fit mechanically?
#14 RegUS_PatOff
  • 33,588 posts
Posted 23 September 2013 - 12:17 PM
maybe
