Replacing Motor Pulley on Admiral AAV7000AWW
4 replies to this topic
#1 Revrebe
Revrebe
  • 2 posts
  • Flavorite Brew:DP
Posted 24 September 2013 - 01:41 PM
Drive belt melted onto motor pulley. I've removed the motor.
I can get the parts I need, but I have no idea how to remove the drive pulley from the drive shaft in ORDER to replace it. Can anyone help?
#2 PDuff
PDuff
  • 2,013 posts
Posted 24 September 2013 - 05:02 PM
Are you sure you can get a replacement pulley?  To my knowledge the pulleys have been discontinued for a while and the only substitution is the motor P/N 21001950 which comes with the pulley.  Even when available it was a chore to remove the pin and melted pulley so when it subbed over to the motor assy that was fine with me.
#3 Scottthewolf
Scottthewolf
    Senpai
  • 2,902 posts
Posted 24 September 2013 - 05:03 PM
According to the parts lookup, a new pulley cannot be purchased. You have to replace the motor.
http://www.repaircli...Number=22004297
Scott Wolf
#4 Revrebe
Revrebe
  • 2 posts
  • Flavorite Brew:DP
Posted 24 September 2013 - 05:59 PM
I went to the parts lookup and found this :  http://www.repaircli...y/21001108/1472
I assumed it was the right pulley since I started the lookup by entering make and model.  Can anyone tell me definitively it IS or IS NOT the right part? (And then, of course, how to get the old one off and the new one on!)
#5 NCARepair
NCARepair
    Kohai
  • Master Appliantologist
  • 324 posts
Posted 25 September 2013 - 08:15 PM
Remove motor and using a hacksaw blade make two cuts 180 degrees apart parallel with the motor shaft, peel off old pulley. Tap on new pulley mentioned. It is slightly different size but does work. Check for anything locked causing belt to not turn.
