Kevinlw
GSL25JFPA BS. GE Refrigerator won't freeze
10 posts in this topic
GSL25JFPA BS.   GE Refrigerator won't freeze.  Inside fan is running, outside Jelly Roll condenser fan is running.  Compressor feels like it's running.  Could it be the evaporator temperature thermistor or the over temperature thermistor?  Or the main board?   Thanks, Kevin
Make sure its is running and take freezer panel off and look for a frost pattern on evaporator.
Hey Bigbuck, thanks for the info.  I removed the cover and there is NO frost on the coil.  A little cool on one end, but that's it.  The heater at the bottom is not on.  Do you know how I can upload pictures?  Thanks again, Kevin
grasshoppers can't upload here directly..
upload to some picture website,
then post the links here
Sounds a lot like a Sealed System Failure, you may be out of luck on this one. Typically if you have a warm feezer and it does not get ice build up after a 30min to hour run time and the evap fan runs then this is the case unfortunately. If you have any images that may help if we can see the evap after an hour of run time.
Thanks, let's see if this works:  https://frig.shutterfly.com/pictures#n_5
I noticed to top of the sensor clips onto the coil has raised, like something inside has gone bad?  I bumped the compressor while running and you can hear it knock a little.  So, seems like it is running..  All fans are running as well.  Thanks, Kevin
Thanks devilslettuce,  I think you may be correct, I just wanted to confirm with the experts....  The unit is about 8 years old.
Thanks again,
Kevin
Has this Fridge been running OK up till now at this location ?
If the Compressor is running and there's NO frost, seems like a sealed system leak.
I see a trip to HomeDepot in your future.
The Defrost Terminator looks bad (common fail)
but that would only prevent Defrost ... not your problem right now.
  • Yep, been running fine and then no cooling...   Yep trip to Home Depot or Craigslist...   :)  Thanks Much...  Kevin
OR Sears Appliance Outlet Store
