Jenn-Air W30400P Door problem and Heating Issue
9 replies to this topic
#1 Greg Blakeney
Greg Blakeney
  • 2 posts
  • Flavorite Brew:Miller
Posted 29 September 2013 - 02:52 PM
I have had a door problem with this oven for some time now. Does not close all the way, light stays on. I see many others have had this issue and it seems as though a 'hinge repair kit' including (what looks like) a new inner liner is the fix. No one seems to say if it is a guess or if this part is actually re-engineered / corrected from original design. I'd just like to know more before I take a $100 gamble. This is the part in question:  Part number: AP4010213
Also, the oven recently stopped heating above ~250 degrees. I saw one other post about this with no answers. Any ideas where to look for that?
Thanks!
Greg Blakeney
#2 PDuff
PDuff
  • 2,034 posts
Posted 29 September 2013 - 03:50 PM
There is a service pointer on this issue.  Replacing the hinges alone would cure the problem but you might as well use the kit.  I've seen damage to the liner at the front oven chassis that I've had to replace, along with the hinges, for proper hinge tension.
As far as the temperature issue,  install the hinge kit first then check oven operation.
    Shōgun
  • Master Samurai Tech
  • 30,177 posts
Posted 29 September 2013 - 03:59 PM
Brother PDuff, do you have the service pointer number on this problem?
Absent that, here's the hinge part link:
Part number: AP4096703
#4 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,484 posts
  • Flavorite Brew:What's on tap?
Thanks!
Greg Blakeney
Service Pointer TDC-0017B-B
The hinges and receivers were re-designed and that is why they come as a kit. The new hinges do NOT fit into the old receivers (never tired it the other way around: new receivers with old hinges), so they must be replaced as a set. (However, if you order JUST the hinges with the original part number, they will fit, but you're back to square one if the receivers are also bad).
Test Access = Hold the stop time key at power up OR hold the stop time key for 10 seconds within 6 min of power up.
Test Exit = cancel key, or will self terminate after 16 seconds after last key command (which is a royal pain in the ass if you stop to think about what you are doing).
Bake key = activates Bake relay on the power relay board
Broil key = Broil relay  on the power relay board
Convection Bake = Convection Bake relay on the power relay board
Convection Roast = Convection Roast relay on the power relay board
Oven Light =  Oven Light  relay on the power relay board
Probe Key = Displays probe temp
Timer Keys =  displays Factory codes in blue, oven temp in red
Clean Key = shows status of door lock switches and the status of user selectable options.
Stop Time key = activates beeper at 100%, also displays control ID#
Cook Time Key = Displays any fault codes in memory (F0 = no fault codes)
Digital Input keys = show same digit in display
Edited by Chat_in_FL, 29 September 2013 - 04:10 PM.
Mother Teresa
The views and opinions expressed in this post are those of the author and do not necessarily reflect or represent the views and opinions held by my employer. All data and information provided is for informational purposes only.
Big Brother
#5 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 29 September 2013 - 04:16 PM
http://appliantology...inges-bulletin/
Maytag Oven
Door Hinges Bulletin
TDC-0017B-B
Install kit number 12002111 for single and combo units
Install kit number 12002112 for double units
Part number: 12002111
Part number: 12002112
#6 Greg Blakeney
Greg Blakeney
  • 2 posts
Posted 29 September 2013 - 05:05 PM
WOW - Thanks for all of the quick replies!
I cannot open the above bulletin - says I do not have permission.
However, the two links in the post just above this - those are OEM hinges and receivers?
The kit I posted above has the redesigned arms I suspect?
I'm not trying be the cheap guy, but if the new kit fixes it and is $70 cheaper I guess I will go that route.
Thanks again!!
greg
#7 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,484 posts
Posted 29 September 2013 - 05:40 PM
You only have to replace the panel if it is visibly deformed. I've only had to ever replace just the hinge & receiver combo parts listed above.
Mother Teresa
Big Brother
#8 RegUS_PatOff
  • 33,588 posts
Posted 29 September 2013 - 06:46 PM
... I cannot open the above bulletin - says I do not have permission.
sorry, grasshoppers can't download files from here,
but here's another link for the Service Pointer
http://www.mediafire...TDC-0017B-B.pdf
#9 Chat_in_FL
Chat_in_FL
    Havoc
  • 1,484 posts
Posted 29 September 2013 - 06:56 PM
 Couldn't download it either, but could from the second link - Thanks!
Mother Teresa
Big Brother
#10 RegUS_PatOff
  • 33,588 posts
Posted 29 September 2013 - 07:02 PM
... Couldn't download it either
uploads now need to be approved by the Samurai
