Juju13
Frigidaire Affinity Washer Model LTF7000ESO
5 posts in this topic
     My Frigidaire Affinity washer is not draining all the way. I have already cleaned out the coin catcher and the problem is still there. I noticed that during the final spin and the spin only cycle the washer turns off with 5 minutes left. Do you think I have a timer problem?
I have to do all of the repairs myself so please help me with the diagnosis and how to fix the problem.
Thank You
Juju
Is the washer doing the final high speed spin or is the final spin slow?
No, the washer is not doing the final high speed spin.
If it spins at all, even if slowly, then you most likely have a bad speed control board:  http://www.repairclinic.com/PartDetail/Motor-Control-Board/134743500/1191307
If it neither spins nor tumbles, then the speed control board is most certainly bad.
OTOH, if it never even tries to spin, then you probably have a bad door latch assembly:  http://www.repairclinic.com/PartDetail/Door-or-Lid-Latch-Assembly/131763202/1531974
One test you can do on the door latch assembly is to put the washer into a spin and let it run for a couple minutes then turn it off and unplug it.  If you can open the door right away, the door latch assembly is bad.
   ...  My Frigidaire Affinity washer is not draining all the way.
It won't do a high speed Spin until it Drains the water.
It should still try to do a low Spin.
How's the Drain line ?
any changes lately ?
Is the Drain Pump running at all ?
