GE Dryer model DX2300EE1WW
7 replies to this topic
#1 llky
llky
    Sōhei
  • Chief Appliantologist
  • 220 posts
Posted 02 October 2013 - 01:23 PM
Looking for a service manual for the GE dryer DX2300EE1WW.
#2 olyteddy
olyteddy
    Kohai
  • 444 posts
  • Flavorite Brew:Earl Grey
Posted 02 October 2013 - 08:53 PM
Looks like a fairly typical GE dryer. What kind of problem(s) is it giving you?
#3 llky
llky
    Sōhei
  • 220 posts
Posted 03 October 2013 - 12:26 PM
It won't run.The motor just  hums.How do you check the motor?And what else could be causing this problem?I need a service manual or maybe the wiring diagram as mine is missing.
#4 PDuff
PDuff
  • 2,159 posts
Posted 03 October 2013 - 01:53 PM
If the motor humms, then it's getting voltage.  Indications are a bad motor or a restricted blower.  With the unit off, try rotating the drum.  If the drum turns, you may have a bad motor.  If drum doesn't turn, there may be something stuck in the blower.  Remove the top and front panels to inspect blower.  If the lint filter is broken or missing there may be a laundry item in the blower housing.  If the dryer vents directly through an external wall, there may be a snake/frog/rat/squirrel in the blower housing.
#5 llky
llky
    Sōhei
  • 220 posts
Posted 03 October 2013 - 03:21 PM
Thanks for the info and help.I checked and the drum does turn.There is nothing in the blower,but it is hard to turn Should it turn freely?
#6 PDuff
PDuff
  • 2,159 posts
Posted 03 October 2013 - 04:55 PM
Normally there is some resistance if the belt is intact.  Sounds like a bad motor.
    Shōgun
  • Master Samurai Tech
  • 31,396 posts
Posted 03 October 2013 - 07:00 PM
http://www.repaircli...ber=DX2300EE1WW
#8 olyteddy
olyteddy
    Kohai
  • 444 posts
Posted 03 October 2013 - 09:11 PM
Did you look up behind the control panel for the diagram?
