fisher & paykel top load dryer bearing truble
5 replies to this topic
#1 brm
brm
    Sōhei
  • 151 posts
Posted 04 October 2013 - 06:14 PM
mod# de62t27g
the bolt that holds the bearing  SHAFT BEARING INLET gust turns on the out side of panel so im having trouble removing the SHAFT BEARING has anyone run into this?
any help how do i remove shaft
thank you
#2 Applianceman97
Applianceman97
    "Hollywood"
  • 2,507 posts
Posted 04 October 2013 - 07:30 PM
You have to take the top off the dryer and the front. Then the inside of the dryer is on a hinge. You can lay the whole tub assy down in front. Just pull forward. Unhook the ground wires first below the drum. Then you can access everything u need.
#3 brm
brm
    Sōhei
  • 151 posts
Posted 05 October 2013 - 04:27 PM
yah i did not wright the problem well, getting access to it i have no trouble. the problem was the bolt that holds the bearing shaft was spinning. so the shaft wood not tread out and  off the bolt.
so what i did was remove the side panel took it home and on a proper bench drilled out the head of the bolt 1/8 inch off eage on two sides drilled it all the way thurw  panel. got a set of needle nose vise grips i had to take these to the grinder to make them fit. set vise grips in holes it held grate and i was able to remove bearing shaft.
#4 richseattle56
richseattle56
    Kohai
  • Chief Appliantologist
  • 418 posts
  • Flavorite Brew:Coors Light or Vodka
Posted 17 October 2013 - 07:34 PM
You need to hold the bolt in place. Watch this video.
http://vimeo.com/alb...3/video/6316564
#5 suampman
suampman
    Kohai
  • Chief+ Appliantologist
  • 307 posts
  • Flavorite Brew:redbridge
Posted 19 October 2013 - 10:51 PM
Thanks for that video Rich. I have not run into one of these yet.
#6 richseattle56
richseattle56
    Kohai
  • 418 posts
Posted 30 October 2013 - 08:13 PM
I just did my first one the other day. The Allen bolt was froze, had to drill it out. Interesting design.
