srockman9_6432
Kenmore Dishwasher 587.14409400 not cleaning well - Continued
10 posts in this topic
(Sorry to start a new thread, but I had all kinds of issues logging in).
My daughter's dishwasher still doesn't clean well.
I checked the filters, checked for blockage in the spray arms, and checked the water levels. They all appear to be ok.
I confirmed that my daughter was using the correct amount of soap, the dishes weren't overly dirty when going into the dishwasher, etc.
However, I checked the water temperature and found that after filling the water was only slightly warm. I used the Hi Temp Wash button. According to the manual:
"When HI-TEMP WASH ON option is selected, the dishwasher heats the water in the main wash to approximately 140°F (60°C). Wash action will continue but timer will not advance until proper temperature is reached."
This does not appear to be happening. Wash immediately starts after filling is complete. The water doesn't heat, nor does the unit appear to be waiting for the temperature to get to 140F. The dishes are hot when the drying cycle is done so the heat coil seems to be working.
Bad switch? Control Board?
I appreciate your help!
http://appliantology.org/files/file/1281-frigidaire-dishwasher-kenmore-5871440/
Frigidaire DishWasher
Kenmore
587.14402400
587.14403400
587.14409400
5995491064 parts
672060709962 tech
similar to
http://appliantology.org/files/file/1280-frigidaire-dishwasher-fmb330rg/
Frigidaire DishWasher FMB330RG
5995498770
2007 18 Inch Built-In Dishwasher
FMB330RGB0
FMB330RGC0
FMB330RGS0
service manual
467_10.pdf
When I click on the link I am told that I do not have permission to access it.
... sorry, not for grasshoppers
Become an Apprentice:  http://apprentice.appliantology.org/
Are you runnin the hot water to the sink before you start the dishwasher? Same idea as running the shower before you get in. You don't turn the water on and get in right away, wait untill it is warm/hot.
The water is actually not very warm which is why the Water Heat option is used. But it doesn't appear to be working.
Do you have one of those "eco friendly" water on demand hotwater heaters?  if not, run the water at the sink until it is hot, too hot for your skin, before starting the dishwasher.  The in sides of this machine may need cleaned by taking apart and sucked out with a wet vac.  Clean the wash arms of crud by running some water into it and shaking it out, repeat until clean.  Same goes with any screens.
No dishwasher is designed to have cold water enter it and heat it from that cold to hot hot.  You will continue to have washability issues until the hot water issue is resolved.  They are hooked up to hot water because that is what they were designed for....
Random last question, is it hooked up to hot water? (It should be)  One of my companies accounts (400-500 units) recently discovered a good chunk were hooked up to the cold side.  All had been replaced multiply times due to washability issues (before we came into the picture)... all due to a bad plumber during the build.... it happends.
Edited by micabay
If the unit heats during the dry cycle then the heater, operating and hi limit thermostats should be ok.  Mechanical timer should be ok so there's a good chance it's the option switch.  Using the wiring diagram check continuity of the contacts when each button is pressed.
Concur with Brother micabay about running the hot water at the sink.  Most dishwashers require a minimum incoming water temperature of at least 120 degrees to ensure washability.
 Unit has a normally open thermostat inline with the timer motor. if this was stuck shut, the timer would bypass the wait for the water to heat, but the heater may still work during the dry cycle...
(somebody correct me if I am wrong).
Edited by Chat_in_FL
