Sign in to follow this
Followers 0
raeben
Whirlpool Front Loader filter cleaned - mystery 1/4 inch black hose
3 posts in this topic
While I was at work this week my adult daughter got the F2 error on our family's Whirlpool front loader.  She disassembled the pump and filter and cleaned it out. When she reassembled she still got the F2 error, so she tried a few "button/reset sequences" she found on the net and finally gave up. She thinks we need a new pump.
She left the pump and hoses, which need replacement or cleaning, disassembled.
So this morning my husband and I start the reassembly and troubleshooting procedure.  I found a penny in the large, black, flexible exit hose that feeds into the pump, but otherwise everything connected to the pump and the pump appears to be functioning.
However, there is a 1/4 inch black hose about 2-3 feet long which is dangling down and no one seems to know what it is or where the dangling end should connect to.  Several people seemed to think it was some sort of "vent hose" which I thought was unlikely, but I can find no mention of it, so I let it dangle.
Running Rinse/Drain/Spin cycle no serious problem encountered... we do have a slow leak around the door seal, but that's all.
Running the Delicate cycle however,  the 1/4 inch black hose spew water to beat the band.  The tank also appears to be overfilling with water and oversudsing although so far no error messages have appeared.
Clearly repair by committee is not working.  :(
Does anyone know what this 1/4 inch black hose is and where should the dangling end go? The hose appears to starts about half way up the tank on the right side.
The gurus will want the model number, so you might as well get that posted before they get here. :wink:
1 person likes this
Could be the water level sensor hose ... one end connects to back of the tub, the other end to a pressure sensor likely mounted at top of the cabinet (accessible by removing the top panel).
You've got the lower panel off to access the pump, and presumably the disconnected end of the hose in-hand.  "Dangling down" infers the other end is connected somewhere, perhaps to something up higher inside the machine that you can't see?  (which case the hose is disconnected from the tub)
Or is the 2- to 3-foot length of the hose mostly laying loose on bottom of the machine, with one end connected perhaps somewhere on back of the tub?  (which case the hose is disconnected from the pressure sensor)
Followers 0
