  • Announcements
jlandis
maytag neptune mde6800a won't start
11 posts in this topic
I have the dryer listed above.  It started and then would not start again.  I have power and the lights are blinking.  I think that is because I tried to put it into the diagnostic mode.  However now that it is in there it will not bring up any codes and just keeps going through this blinking.  I cannot get it to exit the diagnostic mode and it will give me nothing in it.  It seems like the control board is just not operating correctly.  Hard to make any other diagnosis with this not working at all.  Can you help?
... I cannot get it to exit the diagnostic mode
have you tried un-plugging the Power Cord or re-setting the House Circuit Breaker ?
wait about 10 min befor plugging it back in.  this may let the computer reset itself.  Worth a try!  Good one Grand master!
That doesn't seem to make any difference.  I have unplugged it numerous times and left it for over 8 hours unplugged.  It still comes back in the mode that appears to be a diagnostic mode.  The lights all go on but at different intervals successive until they all go on at once.  Then they all go off and start over again.......
buy a new board from repair clinic and try it.  If that's not it you can return it.  I'd venture to say there is an above average chance it's the control board.  I wouldn't bet my house on it but it sounds like the board is stuck now  and probably needs to be replaced. That's what I would try.  Maybe someone else has a better idea.
Thanks, that is what I suspected.  I will wait for other ideas, but that is my guess as well.
It's hard to tell if the main control is bad, or if it's the user interface when nothing responds.
It should however at least reset itself if unplugged.  I agree it is hard to tell but if the control is not responding to any input, dosen't it sound like it's bad to you?
I take that back, It could also be a shorted membrain on the control panel.  So sorry for the miss information.  I could probably do more in a way of diagnosing the problem if I was there but down here in Costa Rica what I do is put in a new control panel and see if that fixes it.  In the previous post I said it should reset itself however it won't if the control panel is shorted.  That happens alot down here as we have high humidity and moisure seems to mess these things up.  I know with the proper scimatic you can test the touch pad but I don't have the luxury of that stuff so my only option is to change it and see.  It's also the cheepr of the two options.  Again, good luck
Thanks,  let me run one stupid thing by you.  When I bought this dryer it had a four prong plug on it.  I have a three pronged outlet so I changed the plug on the dryer from my old one.  is there any chance that this could cause such a problem?
... Thanks,  let me run one stupid thing by you.
... When I bought this dryer it had a four prong plug on it.
... I have a three pronged outlet so I changed the plug on the dryer from my old one.
... is there any chance that this could cause such a problem?
:woot:
pictures ?
If not wired correctly, it can blow out the Controller and the Motor
... Center wire to the center post on the terminal block,
... the two outside wires to the outside posts on the terminal block,
... run a ground wire from the center post on the terminal block to a ground screw on the dryer case...
th?id=H.4655002717389825&pid=15.1
copper strap (center) must be connect center terminal to chassis
