Learn how to be your own tech line...
Sign in to follow this
Followers 0
PEvans
Maytag CWE5500BCE Wall Oven Service Manual Request or Glass Replacement
5 posts in this topic
I need to replace the inner glass on the upper door. It looks like the part is available, but I don't know how to disassemble the door. Does anyone have a service manual?
instructions not mentioned in service manual
Does it say how to get the door off? It looks like there might be tabs on the door side of the latch that you fold out to hold the latch mechanism open.
... Does it say how to get the door off?
16000082
SECTION 9. DOOR
LIFT OFF DOOR
To remove the door:
1. Open the door to the broil stop position.
2. Grasp both sides of the door and lift up until the door clears the hinges.
CAUTION:
The hinge arms are spring loaded and may slam shut.
Do not place hand or fingers between the hinge and front frame of the oven.
Injury may occur if hinge snaps back.
LIFT OFF DOOR - LOCK LATCH EQUIPPED
1. Open door to broil stop position.
2. Slowly lift door straight up.
3. Open door forward slightly.
Insure that latches swing down into notches on hinges arms.
TO INSTALL:
1. Align slots in door with hinge arms.
2. Open door forward slightly as door slides down onto hinge arms to disengage latches.
3. Allow door to bottom on hinge stops.
DOOR ADJUSTMENT
Each side of the door can be adjusted for vertical height by adjusting the screw located on top of the hinge arm.
Thanks very much. I will try it.
Followers 0
