danramos
Needed. Instruction Sheet. Drain Pan Heater Kit for Viking Refrigerators G50911853
4 posts in this topic
I own a DFSB423 Viking refrigerator which I believe has a Drain Pan Heater Kit installed. This supposedly helps to accelerate water evaporation from the drain pan. Mine needs to be emptied like one or two times a month. In the past, tt only needed to be emptied like once a year. I should have a problem with either the defrost system in the refrigerator or a malfunctioning drain pan heater. My refrigerator also has a 24V DC "service fan" (or maybe an fan that helps evaporate the water from the drain pan) underneath the fridge that is disconnected. I am not sure if the previous house owners (the refrigerator came with the house) had this drain pan heater kit installed and had the service fan disconnected as per the drain pan heater kit instructions. I don't have the instructions so I can't really tell.
So, if by any chance, you have the installation instructions for the Drain Pan Heater Kit part number G50911853, would you be kind enough to scan them and post them here or send them in a private msg?
Thank you very much.
You need to reconnect that fan, even with the heater, the pan will still overflow without the fan.
most of the time this fan is disconnected because it got noisy (it should have just been replaced)
expect to get a 3 am wake up call from the fan motor
I don't know how but these things always know when it's 3 am
I think I finally solved my problem. Found the Drain Pan Heater Kit Instruction Sheet and verified all connections were right. Bought an axial dc fan part number 004551-000 and replaced the old one. Found that the old one was disconnected because it was shorted out with the bracket mounting screw probably from factory. Once I removed the old fan, I fixed the cable and connected to a 24 dc source and it worked fine, so now I have a spare dc fan. The drain pan seems to be holding off fine. Haven't had to empty it in about 3 weeks. But I also can tell that the frost build up in the top of the freezer is gone. I did however, replaced the high voltage board prior to all the above as suggested in this threat: http://applianceguru.com/forum1/26676.html . There is a small amount of condensation in the fridge side near the "fresh food DC fan" but I believe is related to the door gasket which did not pass the dollar bill test.  Hope this help to others looking for similar issues.
