Marni Hay-Swart
Kenmore 11066742500 won't heat
9 posts in this topic
Lost heat after drying a chenille blanket that lost all its "stuff" into the dryer vent.  Woops...
Just replaced the thermal fuse and it still has no heat. Already checked the breaker and cleaned out the vent both in the unit, to the wall and at the exterior vent.
What should I try next? I was thinking of ordering the thermal cut out fuse kit
Does the Timer advance in both the Timed Dry and the Auto-Dry cycles ?
Get yourself a cheap meter and check for continuity on your other themostats as well as the heater elements.  the small thermostat on the top of the element housing often goes bad as well.  Make sure you are getting power to the element. you should be able to put the meter on the contacts of the heating element and check for 220vlts.  without a meter you will just end up buying parts until you get the right one.  I'd say that thermo kit you want to order is a good possibility but it could also be any one of the others or a burnt wire or a bad element. Good luck
Thank you! Well, the thermal fuse wasn't it after all - the tester was just out of batteries!  My husband checked all the other connections (apparently he doesn't trust me anymore..).  All the thermostats had connectivity but he did find a broken wire in one of the heating element coils.
good for you. did you also check for 220vlts at the heating element contacts.  Just a precaution.  Chances are if you replace the element you should be good to go.
Nice tip on that timer test.  I never new that.  Thanks
some models,
depends on how the Timer is wired
some models use 120v Timers,
with or without a resistor
(depending on the circuit)
some use 220v Timers
