ge dishwasher driving the family crazy
3 replies to this topic
#1 Guest_toneytigger_*
Guest_toneytigger_*
  • Lurking at the Threshold
Posted 08 May 2005 - 05:21 AM
this dishwasher has a ghost in it # 2bd3000r35wb it starts the draining process and run fine for about 30 sce and then stops and gives me an error code of c3 ive check the drain hose the air gap and even ran it with the hose out the window to be sure it wasnt my sink drain snd still no go any ideas?:?
#2 Guest_toneytigger_*
Guest_toneytigger_*
Posted 08 May 2005 - 05:50 AM
just another kink in the mix even when I use the reset button it drains for a couple of seconds and the stops
  • 24,220 posts
Posted 08 May 2005 - 04:35 PM
Not sure what number that was you gave, but it wasn't a model number. Re-check it.
#4 Guest_russotto_*
Guest_russotto_*
Posted 12 May 2005 - 05:29 AM
It's a Zed, not a Deuce.  ZBD3000R35WB
Having had one of  those accursed electronic-control GE dishwashers, I remember an intermittent C2 code which wouldn't go away no matter how many times GE warranty service came out.  That one turned out to be a slightly chewed rubber seal allowing a little drain water to leak back in.  C3 means that the dishwasher won't go into drain at all.  Since it obviously IS doing so, the question is what the clever GE engineers use to detect that condition.  My guess would be abnormal current on the drain solenoid, which could be caused by a bad solenoid or a partially-blocked valve.
(grumble, grumble, an old non-electronic dishwasher would just take a little longer to drain, but continue to work)
Or I could be totally off base.  Always a likelyhood.
