Amana Washer making screeching sound during agitation
4 replies to this topic
#1 DIY wannabe
DIY wannabe
  • 3 posts
Posted 08 October 2013 - 12:53 PM
My Amanda washing machine (Model: LW8203W) recently started making a screeching sound during agitation. It only happens 5 or 6 times during each agitation cycle. I've never opened the front of a washer until today, so I don't really know what I'm doing, but I took the pump partially out and didn't see anything trapped in there. Any suggestions?
#2 Scottthewolf
Scottthewolf
    Senpai
  • 2,949 posts
Posted 08 October 2013 - 01:02 PM
Check all the pulleys and see if they turn freely by hand, including the belt tensioner.
Scott Wolf
#3 DIY wannabe
DIY wannabe
  • 3 posts
Posted 08 October 2013 - 02:14 PM
When I went to see if the belt would turn freely by hand I saw that it is very worn. It does turn freely. Could it be that the belt is slipping and causing the screeching?
#4 PDuff
PDuff
  • 2,045 posts
Posted 08 October 2013 - 02:16 PM
Does it make the noise during spin?  If it does inspect the bearings below the outer tub for rust, which would indicate a hub seal leak.  If noisy only in agitation, it could be a stripped drive hub under the agitator.
#5 DIY wannabe
DIY wannabe
  • 3 posts
Posted 08 October 2013 - 04:40 PM
It only makes the noise during agitation.
I'm trying to remove the agitator. I got the softener cup off. There is a tall medal post inside the agitator. Do I need to somehow unscrew that or do I just pull up on the agitator?
