Archer973
Is it a Kenmore or a Whirlpool?
12 posts in this topic
I have a  broken dishwasher in the house I bought. The front panel has a Whirlpool Gold logo and a model name QuietPartner III. Inside the door there is a label with Kenmore model number 665.17342301. I guess that Whirlpool made this model for Kenmore. I ordered a new Touchpad Control Panel for the machine from RepairClinic using the Kenmore number. They didn't have a picture of the part I was ordering on their website at the time I placed the order. When I received the new part, it was wrong--wrong buttons, fewer features and it had the Kenmore brand name and model name QuietGuard 2. I'm working with RepairClinic to resolve the problem, but out of curiosity I'm trying to find out how this happened. Is the Kenmore model number correct for the machine I have?
Since the unit was manufactured by Whirlpool, it sounds like somebody replaced the console w/membrane switch with a comparable Whirlpool console.  The correct replacement console (Whirlpool made) P/N 8557769 or 8557770, depending on color.
Thank you for your reply. I had considered this a possibility, but the two consoles are vastly different. The Whirlpool console has several features not on the Kenmore console. It seems to take advantage of the Whirlpool console, the control board would also have to be replaced so now my question is can a Kenmore QuietGuard II be upgraded to a Whirlpool QuietPartner III by replacing the console and the control board? For this to work, it seems all other components and wiring of the two machines would have to be identical.
New information. I finally removed the old control panel from my dishwasher and compared it to the one I purchased. New one is physically larger in height (about 2" greater) and cannot be used. This means that if someone upgraded the machine, they would have had to replace the whole door, not just the control console. Is it possible that the Whirlpool assembly line put the wrong label in the machine with the wrong Kenmore PN? That seems more likely to me than someone realizing they can upgrade the machine by buying a new door for a different machine. But I did learn the answer to my question about the control board. Both machines use the same control board.
a "retailer" / may have used factory "scrapped" parts from scratch & dent units
to build a unit and then sold on eBay or Craig's list.
Ok, that explanation works for me.
Thought I would make a final entry on this topic. I ordered a new control panel and TCO from repairclinic.com. This machine is now fully functional and my wife is much happier.
I would agree with the poster that suggested that the unit has been pieced together, probably by a used appliance dealer. It would be cost prohibitive and very unlikely that a DIY'er would have gone to the trouble to attempt to :Upgrade: the unit. For future parts purchases I would go with the Kenmore model number, although most of the parts other that the console/touchpad assm likely will be identical to the Whirlpool model.
Hi ApplPro. You make a good point about using the Kenmore model number for other parts purchases. If this is a pieced together machine, then the door must have come from a Whirlpool and mounted on a Kenmore, so I would need to take that into consideration if ordering parts for the door, e.g., panel, hinges, latch, etc. The Kenmore number should apply to everything on the main cabinet. Thanks for the advice. I will keep it in mind for future repairs.
A more likely scenario is the original touchpad went bad and someone replaced it with a used one from a Whirlpool machine.
The only difference between the Whirlpool and Kenmore touchpad/console assemblies would be the Kenmore and Whirlpool wording on the front of the panel and maybe a slight different placements of some of the touchpads.
Hi Sensei. I was thinking the same thing until I discovered that the door of the two machines is physically different. The control panel of the Kenmore machine is about 1 1/2" greater in height than that of the Whirlpool machine. If this machine started out as Kenmore QuietGuard II, the door would have to be replaced with a Whirlpool QuietPartner III door for the control panel to fit. As I was typing this I realized that maybe they could have replaced both the door panel and control panel on the door frame, but I don't have enough knowledge to know if that scenario would work.
