RedToryTy
GE SxS GSS22WGPDBB freezing food AFTER initial repair
9 posts in this topic
To the Dojo,
This SxS presented with a defrost failure--defective single-tube heater AND bimetal. Evaporator defrosted, those components replaced, and solid thermistors installed. Also, based on experience, I clipped the damper motor wires because I've witnessed boards shorted because of shorted damper wire. Buttoned everything up, and fridge began cooling.
Catch up to yesterday's frustrating call about frozen food. Pulling the control board cover, I ohmed the thermistors, guessing at correct values based on the GSS/PSS manual posted elsewhere; diagnostic mode never yielded useful results. What I know is a good board is getting data from good thermistors. It even cycled off a couple times.
Today I closed the damper three-quarters, and am having the customer watch it. I await your howls, rotten tomatoes, dead cats, and cries of "PCM!"
Nervously yours,
Red Tory Ty
You should have never clipped the damper motor wires.  Now you have to replace the damper motor.
Cut the damper motor wires??? Never have had a problem with the control boards shorting from the damper. New damper time.
Damper assembly: Part number: AP3186598
Never heard of clipping damper motor wires.Were did you hear of that and how did you think the fresh food was going to get cold after clipping wires?And how do you know that board is good you magic or something.
I had to replace damper only "TWICE" on a GE ,  been doing this for 30 years.   Ive replaced more Whirlpool and old Amana dampers.
But as a rule if Refrg.  is 6/8 years old they get a new evaporator sensor, the new improved dual heater & the Board.
1 in 3 bad heaters or sensors ended up having a bad board also.
Yes you charge a little more but you have NO recall, or defrosting evap. coils all over again.
I agree with you on that and also safety thermostat.You can even test the thermistors on your truck stock with a ice bath before you put them in meaning as soon as they become truck stock after reorder them but never really put in a bad thermistor.But when your defrosting evap. and the thermistor is just sitting there i just replace it and the safety too along with that single heater if it subs.to the double.And if its 6/8 years old new board.Those older boards where problems anyway.
Bigbuck!   YOU are Right!     I should have said the safety too, yeah its right there take 2 min to replace both, cost is minimal,
When I was doing (yes beat me with a stick) work for home warranty companies, they did not pay & I did not replace any thing unless it was actually broken.
And yes to old boards were bad,  I am not replacing as many as I used to.  Now its 1 a month , before it was 2 -5 a week.
But thank God for Samsung, them Rice Burning Fridges pay my bills & some.
Oh yeah you spend 2 to 3 k for a fridge you will fix it.  Just like GE, found out if you replace fan motor & board, & on French Door I install a Whirlpool Drain Heater (theirs is as small as their weenie,) (sorry I thought it was funny could not help my self) (was never known to be politically correct LOL)    along with new fuse & thermistor, never a call back.
You know im gone get edited or banned for this, LOL
Edited by dimitri77565
Clipping the damper wires and manually adjusting open the damper worked on another electronified GE before. And, yes, one of the damper motor wires was grounded inside the cabinet (measured with VOM with damper motor and board disconnected).
I manually opened the damper--too wide at first--but the homeowner and I have adjusted it closed until it is now cycling at 38 degrees in fresh food. But I will take the admonition of The Dojo and replace the damper. Just know you don't NEED an electronified damper.
