Kenmore 106.8682880 Fridge No Ice & Fridge Not very cool
25 replies to this topic
#21 sparkydm
sparkydm
    Ikkō-ikki
  • Chief Appliantologist
  • 42 posts
Posted 11 October 2013 - 06:00 AM
I think there were 2 things going on. I know that the fan motor was bad. after looking at the door gasket, the lower left has a tear in it.
Someone mentioned on a video about spills making the gasket stick and then tearing when the door is pulled open. I've replaced the
fan so, now I'll start looking for a door gasket. Thank you!
#22 sparkydm
sparkydm
    Ikkō-ikki
  • 42 posts
Posted 11 October 2013 - 08:54 AM
I had both problems, A fan motor not working and bad door gaskets. Changed the fan, cooling great now. Picked up both door gaskets and getting ready to change those
today also.  Thanks.
#23 sparkydm
sparkydm
    Ikkō-ikki
  • 42 posts
Posted 23 October 2013 - 09:21 PM
Fridge/Freezer working now. Installed new gasket a few days ago. 3 of the freezer door corners are about 3/4" from the freezer. The lower left is
about 1 1/16" from the freezer face.  The gasket screws are all snug. There's a little ice starting to form along the top forward section of the freezer.
As if moisture is getting in. I've attached photo links to show the difference in the corners.
3 corners, upper left & right, and the lower right of the door are are about this distance from the freezer door face.
http://s908.photobuc...html?sort=3&o=0
1 corner, the lower left, is about 1 1/16" away from the freezer face and isn't sealing properly. It was further away but, sealing when installed
last week.
http://s908.photobuc...html?sort=3&o=1
Any ideas on what would cause the door not to be square? The door gasket is new with no tears/rips. I bought it from Repairclinic.com .
#24 Cactus Bob
Cactus Bob
    Senpai
  • PipPipPipPip
  • 553 posts
Posted 23 October 2013 - 09:50 PM
loosen all the screws a little bit , not real loose but a little , this will keep the liner from cracking
hold the bottom of the door closed , and pull the top open a little bit until the door is correct
snug up each screw on each side of each corner , this is a total of 8 screws , recheck the door , if still good snug up all the rest of the screws
the reason i use the word "snug" is you don't crank down on these screws like you might think , as the liners age , they crack real easy , so be careful , with a light touch
SORRY ABOUT THE SPELLING , I FIX GREAT , I DON'T SPELL WELL
#25 sparkydm
sparkydm
    Ikkō-ikki
  • 42 posts
Posted 24 October 2013 - 08:40 AM
I'll let you know. Sounds like it should work! TKS!
#26 sparkydm
sparkydm
    Ikkō-ikki
  • 42 posts
Posted 24 October 2013 - 09:08 AM
Applied the "Kata" suggested by Cactus Bob and I've posted a picture of the results. Thank you "Sublime Master"!   :woot:
