wcvh4800k1ww GE Front Loader
micabay
Currently looking for some reading material for this lovely machine.  Already got the one from this:  http://appliantology.org/files/file/273-ge-31-9135-front-load-washer/ but it seems to be a different design of machine.  Stator rather than belt driven, smaller, different interface.... thanks for the help.
MicaBay
  • micabay
  • dimitri77565
Looks to be an LG, as far as I know & Please some one correct me they are they only ones using a "Hall Sensor" that can be bought separately. All others have hall sensor as part of stator.
