  • Announcements
scootdog85
Frigidare front load not going through cycles. (or draining)
10 posts in this topic
Okay, I am sure you have heard this one before but I can’t find a clear answer on the net. I have a Frigidaire LTF2140fs2 front load washer.  My wife noticed clothes wear still soaked. I took the filter out of the drain hose, cleared it and put it all back together. I put in drain/spin mode and I heard a loud HUMMMING noise followed by a little water draining then nothing. I cleared the board,  then forced the machine into the drain/spin cycle it paused for 2 mins like it was wanting to drain, then It spins and came to an end. However the control board stayed in final spin and lock position (control board lights). I had to cancel load to open door and noticed water still in barrel. I cleared the machine and put it back on normal wash load and attempted to run a full wash. The water kicked on then off immediately, the board clicked and went to no spin and lock. So I don’t know if I have a control board issue or if the drain pump and water in barrel are not allowing me to run another load.
Hope this makes sense if not I can try to attach video or pictures.
Update: I put washer into Diagnostic mode and every time I change the cycle selection knob it makes a loud grinding noise. I turned the knob 9 spots and got 5 led lights blinking. Still lost.
Has this Washer worked OK for you up till now at this location ?
Have you cleaned out the Pump ?
Drain Pump is behind the front bottom plate.
Raise the front of the washer and insert a two by four under the front of the washer.
Remove the (2) screws holding the panel to the washer base.
Pull the panel down and out.
Yes I removed the pump and was all clear. Was a little hard to rotate the impeller. Hooked all back up and started the above issues. Yes has been working perfect for 4 years at this location.
I agree, bad pump.
I'll get one this weekend and update y'all. Thanks.
sounds like a bad Pump
may need to check for 120v AC at the Pump when it should be running
http://www.repairclinic.com/referral.asp?R=154&N=2754548
Buy it through the link Reg posted above and you could have it tomorrow, with a one-year return policy!
Update. It was the Drian Pump.
sorry for delay have been out of town for work.
no problem, glad to hear of your success!  Thanks for sharing!
