Pop-Pop
GE gas dryer runs, no heat
10 posts in this topic
GE M#DCVH640GJ1WW gas dryer runs, but does not heat. Vent line was cleaned about a month ago-had a serious lint build up.  So, I'm thinking thermal fuse or high limit T-stat. Checked Hi limit, safety T-stat, thermistor and inlet control T-stat with continuity tester.  All controls good except no continuity on thermistor or inlet control T-stat.  Bought new parts and guess what, they have no continuity either.  [They have not been installed in dryer as of yet.] What is the proper way to test these parts??  Any suggestion where else to look?? Thanks.
I did not check the ignitor yet. Normally, when a gas dryer is turned on, a "click" can be heard at the start of the heating cycle, or say, changing from air fluff to heat.  I did not hear the click and presumed it was a safety issue.
Can you tell me the proper test procedure for the thermistor and inlet control?
what's the part numbers of what you bought ?
WE4M398 Inlet Control T-stat
WE4M336 Thermistor
WE4M336 Thermistor
those are both Thermistors
and should read about 100k OHMs at room temperature
http://www.repairclinic.com/GE-Dryer-Model-DCVH640GJ1WW-ID-849732-Sensor-Thermistor-Parts
these are your Thermostats
http://www.repairclinic.com/GE-Dryer-Model-DCVH640GJ1WW-ID-849732-Thermostat-Parts
I'm getting about 12K on each. More importantly, the resistance drops as the part heats up [holding them between my finger]. So, I believe those are good.  The other T-stats tested good on continuity.
The next thing I'll look at is the ignitor.
Was able to get back to do more trouble shooting this AM-dryer is at another house. Reinstalled thermistor and inlet control T-stat and rechecked other T-stats. All good.
Did continuity reading on ignitor-checked out good. Just to be sure, bypassed belt switch to get dryer to run and ignitor did heat up.
Then did readings on coils. Main okay, the second was open between two of the pins.  The last part I Checked.
Dropped in a new set......  all is well.
Lessons learned: the problem may not be the first thing BUT may be the last thing you check!  Also, check ALL possible parts the first time around and then,double check.
Thanks to all who gave input.
Glad you got it working Pop Pop.
Many of us would probably gone straight to the ignitor first.
If it works you then check coils and gas valve and gas supply.
If it did not work,we would back tyrack through other components.
Well,I don't really know about what "many" of us would do.
That is what I would do.
Thanks.......I actually had the clue in my original observations as mentioned in post #3. The "click" I was not hearing was the dead solenoid.
In thinking back over this, I realized I approached this with a preconceived notion that it was a thermal cut out problem because the tenant had been using the dryer for quite a while with the vent line loaded  with lint......."it takes several cycles to get my clothes dry". The dryer chassis was pretty "linty" too, which we cleaned out.  [Any one else thinking dryer fire????]
