FAQs | Store | Memberships | Repair Videos | Newsletter | Beer Fund | Contact
Troubleshooting and Repairing a Warm GE Refrigerator with an Inverter Compressor
GE refrigerator inverter compressor test troubleshoot repair
6 replies to this topic
#1 Samurai Appliance Repair Man
    Shōgun
  • 27,923 posts
Posted 12 October 2013 - 07:36 AM
Watch with shock and awe as The Appliance Guru tracks the problem in a warm GE refrigerator that uses an inverter-type compressor.  These are different animals than the old skool compressor like yo momma used to have.  Inverter compressors are variable speed, variable capacity and use a special control board, called an inverter board (or a Perverter Board) to control it-- no start relay and overload device in these newfangled compressors.
Here's the inverter board I replaced to fix the problem with this refrigerator:  http://www.repaircli...5X11138/2443233
If you live in the Kearsarge-Lake Sunapee Region of New Hampshire, call The Appliance Guru for fast, expert appliance repair service:  http://ApplianceGuru.com
#2 bigbuck
bigbuck
    Sōhei
  • Master Appliantologist
  • 236 posts
  • Flavorite Brew:Red Wine
Posted 12 October 2013 - 09:07 AM
Great job and video and a lot of hands on information of the G.E Inverter Refrigerator.Thanks for all you do.
#3 beam current
beam current
    Yamabushi
  • Chief Appliantologist
  • 72 posts
  • Flavorite Brew:Coke, crushed ice,,,and a straw
Posted 12 October 2013 - 05:03 PM
At 3:43 you said you need a special instrument to measure the frequency at the inverter connector.
Would a DVOM with frequency measurement capability work for this? Or is there something else?
Outstanding video :rocker: !
Thanks for the awesome job you do.
    Shōgun
  • 27,923 posts
Posted 12 October 2013 - 05:17 PM
Great question!
I think a DVOM with freq capability would do it.  The problem is where do you place your probes to make the measurement?  One probe would go in the compressor connector harness but what would be the reference for the other probe?  DC measurements need to be relative to their own ground so chassis ground wouldn't do it.  I don't know the answer to this question but if someone else does it'd be great if they would post it here.
#5 DurhamAppliance
    Sho' Nuff Chozin
  • 4,001 posts
Posted 13 October 2013 - 10:28 AM
Great video! Mucho excellente.
Two points
1) Most inverter compressors will have windings with the same ohm reading. As you point out, you must check the specs. I use to be under the impression that all inverter compressors were the same (equal ohm readings across the pins) until I came across a Samsung inverter compressor. I was questioning myself, my testing abilities and about to declare the compressor dead since the readings were different and not too unlike a standard compressor. My head was about to explode until I looked at the manual again. The readings were correct and the compressor was fine. So be careful of this trap.
2) Your fingers look marvelous. lol
#6 NCARepair
NCARepair
    Kohai
  • 313 posts
Posted 19 October 2013 - 11:29 AM
Nice profitable job on GE built in. Kind of tense though when you and the customer stare at it for three minutes until it decides to start.
#7 DurhamAppliance
    Sho' Nuff Chozin
  • 4,001 posts
Posted 19 October 2013 - 08:18 PM
I usually walk outside or go to my truck during this period
Also tagged with one or more of these keywords: GE, refrigerator, inverter, compressor, test, troubleshoot, repair
