mcrafarm
Bosch Dishwasher E34 error, won't cycle unless I vacuum sump
17 posts in this topic
I've replaced the drain motor and air gap.  Checked the drain hose for blocks/kinks, tested overflow, raised drain hose loop on the way to the air gap as high as it goes.  Hose from air gap to disposal is clear, plug in disposal inlet removed.  If I shop-vac water out of the sump, making a seal by wrapping a rag around the hose, it will run one cycle.
I *discovered* the HUMIDITY SENSOR above the drain in the sump.  Can anyone tell me if this is part of the drain or startup cycle?  The thing costs $15, so I'll replace it on principal if it's involved. Otherwise, I'm running out of the cheap stuff and face trying a new control module -- not so cheap.
One last thing, which I'll try now, does there need to be another drop in the drain hose between the high point and the air gap?
model number ?
yeah.   SHE6AF06UC/05  The day job finally quieted enough for this, and I'm plenty sick of vacuuming out the sump to get it to work! Please read initial post for description.
I'm not aware of an E34 but an E24 points to a problem with the drai pump or circuit board according to the service manual. But the service manual is wrong.
If it does it at the very beginning of the wash cycle it's most likely a bad wash motor, even though the motor runs fine once you get it to run. The is weak causing excessive current and the board throws the error.
I had two of them about a month ago that threw me for a loop. I spoke with BSH service department and they told me the manuals and tech sheets were wrong.
The error could be the drain motor or the wash motor.
Again this is for an E24.
Pray it's the drain motor.  Very easy to replace.  At least worth trying-- if it doesn't work, return it for a refund:  http://www.repairclinic.com/PartDetail/Drain-Pump/00611332/1557816
Thanks to Spannerwrench and FermentedGM. You're both right, it's error E24.  But I'm still a bit confused: if it is the wash motor, why would it work after vacuuming the sump?   As for the circuit board, you're referring to what's in the rear to one side of the cabinet, at the bottom, and NOT the control panel?
If you're getting the E24, 90% of the time if you open the door it will bypass the error and continue to run.
What do you mean, "bypass the error and continue to run" - I usually still see the E24 if I open it and close it back :)
I'm only able to get mine to run at this point in the customer service test mode (which it exits with 0).  I guess it's time to try a drain pump....
The plot thickens here.  Yesterday upon further tinkering I got E:24,  E:01 and E:25 at different times.  I'm beginning to think there's a circuit board issue, but I'm on the brink of calling the factory service people.
E:25 drain pump error (could also be wash pump), same error as the E:25.
Taken from the service manual.
Opening and closing the door bypasses the E:24 error
code, allowing the dishwasher to continue in the wash cycle
(unless it is reset).
Anyone know what E32 means on a Bosch SHE06AF06UC/05 dishwasher?  I'm back to the dishwasher after the holidays and being tired of washing dishes by hand.  I have essentially re-installed the thing by the instructions.  If I try a normal cycle it still posts E24.  However, I've figured out how to run the Customer Service Program, which runs all the way through, with everything apparently functioning, including draining.  At a few points in the CDustomer Service Program, it posts E32 for a minute, then it moves to the next test.  Anyone know what E32 means on a Bosch SHE06AF06UC/05 dishwasher?
" Reinstalled the thing by the instructions".....What thing???........................... replaced the drain pump????
Earlier in the thread, I explained that I replaced the drain pump.  Yesterday I reinstalled the dishwasher by the instructions.  Again, the Customer Service Program runs completely, cleans and drains, but in the course of the run puts up E32 intermittently.  Bosch told me the E32 is an overload of the drain pump circuit.  Starting any user cycle fails with an E24 code.  I've ordered a backflow valve.  Are you suggesting I should remove and reinstall the drain pump?
The error codes you are seeing all point to a problem with the drain system. Either the drain pump is bad or intermittently bad or there is a blockage in the drain hose. Remove the drain hose from the drain pump and blow through it to see if it's clear. If the drain hoses clear, then replace the drain pump:  http://www.repairclinic.com/PartDetail/Drain-Pump/00611332/1557816
Comes with a 365-day, no-hassle Return Policy:  http://www.repairclinic.com/Layer/Return-Policy
Here is the service manual for your dishwasher with all of the error codes and their meanings:  http://appliantology.org/files/file/234-bosch-ascenta-dishwasher/
You will need to upgrade your membership to download it:  http://apprentice.appliantology.org/
Having a very similar problem with a customer's Bosch EcoSense SHE6AF02UC/05.  5 trips out, 4 times to replace another part.  Customer reports wash cycle would start then stops with error code E24.  Initial visit: I noticed the floor was wet under washer, probably for some time. The customer never knew it leaked as the floor underlayment kept the water under the kitchen cabinets and off the linoleum.  Service codes stored: 24, 25, 31 & 32.
I ran "Regular Wash" which started fine and ran a few minutes then quit with E24.  Held "Start" to cancel & drain.  It attempted to pump (pump cycled), then quit, leaving tub filled with water.  Tried several attempts with no success.  I played around a bit with the service program and next thing you know, it drains all the water out. So I tried running "Quick Wash".  It starts, washes, and while running, I look under the washer only to see water running out the bottom thru float port.  Overfilling??  I stopped the cycle & opened the door... filled with water.  I pulled up on the float several times but it didn't activate the pump nor could I hear it "click", so without pulling the machine out from the cabinets, I decided it was the float switch. Played around with the service mode a bit more and again it drains, so I quit with it empty....but puzzled.
2nd visit:  I replaced the float switch ...but it continues overfilling. DIAGNOSTIC ~SAME ERROR CODES: 24, 25, 31 & 32 & still intermittently not pumping water out.  OK, so it must be the pump motor (E24 & 25) right?   Pulled the washer out, checked the hoses blowing thru them. All clear.  (I expected they would be.  When it did pump out, I checked to see it pouring out thru the disposal drain without any flow problem.  No blockage, so now I check the pump. Specs out perfect @ 89 ohms.  Intermittent problem???  I ordered a new pump.  Of course, the customer probably is now questioning my ability, rightfully so I guess.  But she agrees to a new pump.
3rd Visit: Replaced drain pump,  CLEARED ALL ERROR CODES WITH THE 5 second "Start~On/Off" button shuffle.  Run Diagnostic and all codes cleared. Now I run "Regular Wash" thinking I've finally got it!, but alas, ALL PROBLEMS STILL PERSISTS!  Stops with E24. This time stored error codes add "01" to all the previous codes 24, 25, 31 & 32.  So I took the new pump out, put the old one back in... and ordered a control board.
4th visit: Replaced control board. CLEAR ALL ERROR CODES again.  Start a wash cycle, looking good, sounding good, NO E24,,, GREAT, I finally got it.  I ran a few other cycles successfully, yet why do I feel like something else is going to happen.  You remember I said "Having a very similar problem" at the beginning of my post?  Yep, after a few more minutes, I hear what sounds like it's taking in more water (faint whirring noise from water running thru copper pipes under sink.  HUH???)  Sure enough, I look under the toe kick and..... UGH! WATER DRIBBLING OUT THE FLOAT PORT!  Water fill valve intermittently failing?  It took several attempts to get my multimeter probes in the back of the connector and stay there before I could check the inlet valve fill cycle.  Sure enough, the fill cycle stops (no voltage) and water continues to flow. So now I have to inform the patient customer, I definitely have to replace the fill valve.  Again, no stored error codes.
5th visit: Replaced the water valve.  Run Service program all the way thru.  Half hour later and still unsure, I decide to run each and every wash cycle until I'm satisfied all is OK.  And all is; no error codes, no more overfilling. I packed my tools,and told the customer she can now enjoy her brilliant masterpiece of German engineering.  All this for $398.26.  Worse yet, I go to leave her home that final night, and in the dark find my SUV battery is dead.  I didn't have the heart to tell her I was stuck in her driveway.  Well, I got it started a half hour later or so and had to cancel my last call for the evening.
Five trips out to her home, and still, nothing makes sense:  You know why? Tonight, I get an email from the answering service from the customer, "Chris came out to fix my bosch dishwasher 5 times. Its giving the same error message e24 again."
Any thoughts?  Please, I would be amused.
I'm not aware of an E34 but an E24 points to a problem with the drain pump or circuit board according to the service manual. But the service manual is wrong.
If it does it at the very beginning of the wash cycle it's most likely a bad wash motor, even though the motor runs fine once you get it to run. The (motor) is weak causing excessive current and the board throws the error.
...I spoke with BSH service department and they told me the manuals and tech sheets were wrong.
Wish I found this before I started pulling my hair out. Got a sick feeling Spannerwrench is right in my case.
Simple way to "bypass" the E24 fault. Start dishwasher as normal. Listen for drain pump, When it stops the circulation pump will come on. When it stops OPEN the door. Then close door and dishwasher will finish the cycle. Otherwise replace the circulation motor as it send "FALSE " error code to ECU causing it to fault out and stop cycle,0:00 displayed.
