Learn how to troubleshoot like a Master Samurai Tech...
ReliableApp
Subzero door dispenser issues 695/F2 model will not dispense ice or water
11 posts in this topic
It will not dispense ice or water. Water valves are good.
Problem is I can't get the assembly area apart (attached photo) to get a look at this assembly system.
Looking for instruction on how to disassemble the dispenser area.
Thanks!
post-35919-0-59384100-1381667127_thumb.j
Hi Scott - Thank you for the info. I clicked on the link and it said I needed to sign in?
Oh sorry, it's password protected.
Can you tell me how to disassemble the door dispenser to replace the solenoid assembly?
I got as far as the two screws on the bottom then got worried about damaging something
Edited by Ritz
Use a plastic putty knife to pull the housing off the door or carefully pull it off.
Awesome. Will do!
These dispensers use plastic rivets to fasten the control panel and sump in place.  The control panel has to be removed first by pulling the two rivets out from the bottom and disconnecting the blue ribbon wire.  Then the bezel came ne removed.  Remove two more rivets from the upper side walls and pull out the sump from the bottom.  After that remove the access screws, disconnect wiring, and remove the rest of the dispenser assy.
I saw the two rivets on my first visit. What is your preferred method to remove the plastic rivets?
Thanks a ton!
Edited by Ritz
The rivets are a little tricky and not much room to work with.  If you have some decent thumb/fingernails you can pry out the center rivet head.  If not a small putty knife will suffice.
Hello all.
Thanks for your help and tips!  Installed SubZero Part Number 4204560 Non-Delay Dispenser Assembly and water and ice dispensed on command!
Many Thanks!
