Wirlpool ice maker
3 replies to this topic
#1 mrpatten
mrpatten
  • 2 posts
Posted 03 April 2005 - 10:58 AM
A couple a weeks ago I submitted a request for help on a Whirlpool water and ice maker problem under the name of whackiest general patten. I went ahead and purchased and replaced the defective icemaker and water dispenser valve. The refrigerator now dispenses water but does not make ice. Water does not flow from the the tube located above the ice maker assembly. Is there a water line filter for the ice maker and where is it located. Or am i looking at another problem with the ice maker. Thanks for your input.
Mike
#2 Moostafa
Moostafa
    Senpai
  • The Ayatollah of Appliantology
  • PipPipPipPip
  • 765 posts
  • Flavorite Brew:Poppy Salmagundi
Posted 03 April 2005 - 01:25 PM
Hello, my wackiest friend.  Have you allowed at least 12 hours after installing the new icemaker for it to begin making ice?  Yes, it can take up to 12 hours for the icemaker's internal thermostat to reach 17 of your Ameedican Fahrenheit degrees before the icemaker can make ice.
If yes to the above, have you removed the fill spout to ensure that an ice plug is not preventing water flow?  I caution you not to skimp on this test as many a grasshopper with an untrained eye have deluded themselves into thinking the fill tube is clear when, in fact, it is as plugged up as a cheese-fed yak.
Allahu Akbar!
#3 Ron
Ron
    Kohai
  • 368 posts
Posted 03 April 2005 - 02:42 PM
Mike,  pull the cover off the front of the ice maker and using a jumper wire jump V to L.  This will activate the water valve and water should fill.  You should be able to hear the valve calling for water.  If you jump T&H this will cycle the whole program.  It's possible you didn't have the water line primed...I believe the Samurai has some good
pages available on these ice-makers...Ron
  • 24,211 posts
Posted 03 April 2005 - 03:18 PM
Good advice from both Moostafa and Ron. Thanks, dudes!
