Kenmore oven door lock
5 replies to this topic
#1 Guest_Cheri_*
Guest_Cheri_*
  • Lurking at the Threshold
Posted 08 May 2005 - 07:05 AM
this morning I wen to push the self clean button on my flat range so that the oven could begin cleaning. However, I noticed the door to the oven was not locked, shich seemed odd to me. Then I opened it, and as I did this the door lock sprung out, andnow my oven door lock is out, the light on the range is blinking door open, and the oven controls wont work with the door jarred open. Is there a way that I can get the door lock to go back in?
Thank you,
Cheri
#2 Guest_Cheri_*
Guest_Cheri_*
Posted 08 May 2005 - 12:07 PM
Oh, and I forgot to mention that I was drying out my bras in the oven when the door lock failed.  Hope that helps!
Cheri
  • 24,677 posts
Posted 08 May 2005 - 12:15 PM
Ok, aside from needing your model number to tell you anything meaningful, I'm a little confused as to why you were baking your bras in your oven at self-clean temps?  Self clean gets up to 900F in some ovens.  It's fortuitous that your door lock broke because, had you succeeded with your half-baked plan, you'd have started a fire inside your oven.
#4 FatMan
FatMan
    Sōhei
  • Master Appliantologist
  • 233 posts
Posted 09 May 2005 - 04:32 AM
Cheri
Beam me up Scotty, I'm losing it. I have apaininthesideis:touched:
#5 Guest_Kevin_*
Guest_Kevin_*
Posted 09 May 2005 - 08:23 AM
There must be something in the air..... Minus the "bras" I did exactly the same thing this morning. MODEL Number 911-4742594.  Lock light is flashing and the lock mechanism is deployed: door unable to close as a result. Please advise. Many Thanks!  Kevin - Durham,NC
#6 Kevin
Kevin
  • 3 posts
Posted 10 May 2005 - 10:28 AM
Hey Cheri: Just a shot in the dark....but it worked for me....press and hold-in the switch that turns the light on/off  and the locking motor (or whatever it's called) should reset itself.  I discover this after I disconnected the "locking arm" from the motor and was able to close the door.  Let me know.
Kevin :D
