JV1148
DRYER ONLY HEATS ON CERTAIN CYCLES
5 posts in this topic
Hi everyone looking for some help here.
I have a Whirlpool Electric Dryer Model WED4800X80.
The dryer will not heat up on the timed cycle at all but will heat up on the "automatic dry" or the "very dry" setting.
Any suggestions?
I have checked the switch, the breaker , lint , lint hose.
... WED4800X80
maybe WED4800XQ0 ?
Oooops YES !!  WED4800XQ0
... The dryer will not heat up on the timed cycle at all but will heat up on the "automatic dry" or the "very dry" setting.
doesn't make much sense, but may be bad Cams in the Timer
All cycles use the same Contacts, Auto-Dry controls the Timer Motor
http://www.repairclinic.com/referral.asp?R=154&N=1546812
I know it doesn't make sense. When I use the "timed" cycle either 70, 60, 50 minutes the dryer does not heat up.  If I put it in the automatic cycle it heats up.
