Sign in to follow this
Followers 0
rayzgurl
Kenmore Ultra Quiet Elite 633.13793K603
8 posts in this topic
I am looking for instructions on how to replace the control panel on a Kenmore Ultra Quiet Elite 633.13793K603. I have the part purchased and on it's way. I just need to know how to install the darn thing. ;-)
Thanks!
... Kenmore Ultra Quiet Elite 633.13793K603
My eyesight isn't as good as it once was :blink:   see RegUS_PatOff http://www.youtube.com/watch?v=oPAY2LsKVEw )
but from here it looks like your model number may be
665.13793K603
What makes you think the Controller is bad ?
The fact that my 5yo peeled the start button up and it has been pushed down into the controller... not much fixing that one without replacing it.
Sorry for the fat fingers... you are correct on the model number.
this may help
You'll have to remove the decorative front door panel to access the console.  Be sure to de-energize the unit first.  There will be about ten torx screws to remove from the inside door liner lip.  With the door open at a 45 degree angle, start removing the screws from the bottom first and work your way up.  The four screws at the top are longer since they go through the console to secure the front panel.  Be careful when removing the final top screws because the panel will drop.  Once the door panel is loose, lift it up and away from the door.  Then just switch the main control and latch assy to the new console and reassemble.
Thanks folks! One more issue related to this... the button on the circuit card is wacked and the circuit card will have to be replaced. There are two circuit cards in the door, I need the smaller one with the buttons on it. I have been unable to find these for sale. Can anyone point me in the right direction?
Followers 0
