Matt Moody
12-year old front-loader (Kenmore 417.41042000) -- repair or replace?
6 posts in this topic
Our front-load washer is leaking from the drum seal, and when I pulled off the back panel I noticed gunk around the bearings.  My next step will be to pull out the drum assembly to look at the spider.  If all I need to repair are the seal and rear shell with bearings, the repair parts will be around $250.  I like the idea of keeping this machine going as it has worked well for us, and has not had daily use (so perhaps it's not that old?).  The lack of electronic read-outs on this model also means it works well with our off-grid power system.  Is it worth repairing, or so old that some other part will break soon anyway?  I think if I could hope for a few more years of use, the repair cost would be similar to the life cost on a new washer, since they're only supposed to last 6-7 years.  For new, we're looking at the newer model of the same machine, since it fits in the space and fits the stackable dryer on top.  It's $6-800.
Thanks for any advice,
Matt
PS Where do all the old washers go?
Matt, you're probably gonna find a broken arm on that rear spinner assy, which would require replacing the inner basket along with the rear outer tub.  This washer was manufactured by Frigidaire for Sears and most likely had a 5 year part warranty on the tubs.  Given the cost of the replacement parts and the age of the unit, you may consider a new washer.
In response to your question, all old front load washers go the scrap yard when they die.  Old top load Whirlpool and Kenmore washers come to our shop to be repaired, refurbished, reborn, and resold.
Thanks for the info.  Maybe instead of taking it apart I'll try to test the spider from the front door as I read about earlier today.  If I have to buy a new washer,  I may as well tighten the nuts on the drums and put the rear panel back on this one and keep using it until it actually doesn't work anymore!
We did have one repair call years ago -- can't remember what for -- and the serviceman recommended we use only about 1T of detergent, as well as vinegar in the fabric softener spot.  We have done that since.  Now I remember... we were getting deposits from our hard water.  Problem solved with a water filter.
Just noticed my washer manual says "Limited Lifetime warranty on stainless steel wash basket."  Think it might be worth calling Sears?
you will have to pay for labor
