Don Lay
Maytag 2000 Series MHWE201YW00 E2 F2
1 post in this topic
I took off the lower front panel and took out 2 bobbie pins from trap and put it back together hoping it would start working but that was not the case.  Shortly after I turn it back on I keep getting the same error.  I took out the impellor assembly completely and made sure it could spin freely and that there was nothing on the inside.  It does appear that it will drain liquid out so I'm not sure what is causing the error.  I have to decide what to do next and I'm considering buying a pressure switch.
http://www.repairclinic.com/PartDetail/Pressure-Switch/W10239066/1548491
and seeing if that will fix it or i'm about to make a service call.
Please help!
Don
