GE Fridge Model PDRF2MBXARBB
1 reply to this topic
#1 Gnominator77
Gnominator77
    Yamabushi
  • 75 posts
  • Flavorite Brew:Molson Canadian
Posted 16 October 2013 - 07:48 AM
Hi,
I have this GE fridge model PDRF2MBXARBB that the original complaint was fridge section not cooling well and the freezer was doing okay, but not great. I went and found the evap fan motor not running. Replaced the evap fan motor and board and motor fired right up. Now I'm getting a call that the fridge section is cooling well but the freezer section not so good. Another thing the customer mentioned was the display was reading 37 in fridge but -46 in freezer. What makes the display function? Thermistors in each section? Do the display boards fail often? Any help would be appreciated.
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 5,877 posts
Posted 16 October 2013 - 08:00 AM
did you take temp readings at the evaporator? Also test all thermistors if evap checks out ok
Thermistor testing (at the board) is imperative when dealing with temp issues in thermistor controlled fridges.
www.DurhamApplianceThrift.com
