The days of Monkey Boy Service Calls are over...
Click here to check out our fun short course and learn how to get the most out of Appliantology.
akmsam
Warm beer box Samsung RF266AERS
12 posts in this topic
The beer is getting warm  44  should be at 36.   The vents behind wall are packed with frost.  Do not know if fan is working or evaporator is heating up.   should fan always be running?  What is the voltage fan should see?
I defrosted this a couple months ago, the evaporator was packed in ice.  Never saw or heard the fan run.   The problem is back again.   Appreciate all suggestions.
If it took a couple of months for the f/f evaporator to frost back up, you may have faulty evaporator defrost sensor (yellow wire).  If the evaporator fan is not restricted by ice buildup it should be running, but only with the doors closed.  Most Samsung's use a magnetic reed switch for a door switch that works the interior lights and the fan motor.  A quick way to check if the fan is running is to actuate the switch using a magnet.  Locate the magnet pad at the top of the left hand door and see where it lines up with the control cover.  With the door open, hold a small magnet to that spot on the cover and see if the lights turn off.  A couple of seconds later the fan motor should start.
Edited by PDuff
Used the magnet, but could not hear the fan running.  I guess it could be packed in ice.    I will probably have to defrost the whole unit again to get the back cover off.  I should be able to check the fan once everything is melted.  Should the defrost sensor be replaced?   Where is a good place to buy parts online?
Thanks for the help
Right here, padnah!  Just scroll to the bottom and use the Appliantology Parts Finder.  Punch in your model or part number and all will be revealed.
Does the fan cycle on and off.  Or does it always run when the door is shut?
Got the temp sensor,  Was able to check that the fan is running when the door is closed.  I checked this with the old temp sensor.
Again the back of the styrofoam was a block of ice.   Put in the new sensor and closed everything up, seems to be working.     What is the normal way that the moisture is taken out of the refrigerator?
If I get more build up in a month or two what would my next steps be for trouble shooting?     All help is appreciated
Don't know if your unit is the same as the Lash model or not, but the thermal fuse on the right side could be blown.  Did you check that?  If its blown it will not defrost.  That is Ice build up problem. Not defrosting, blocking airflow.  I need to look up your unit.  You can check this at the control board in back, dont have the J connector number but it was between 7 and 9.
Looking at some of the other diagrams, they may have installed a bimetal thermal.  do you have a print,  I did a search on downloads, but Samuria pmed the manual to the requestor for RF266AERS
Not sure where the thermal fuse would be located.  Is it where the computer board is located?
Have you got a print is the first question?,  The LASH model I had to work on had a thermal fuse (non resetable) that fuse is wrapped in a white plastic foam on the right side of the evaporator, (as you look in frige)   will have to defrost the evap to see it.   Some of the Samsungs use a bi metal thermal, resets its self, but if it fails you cant defrost, no path to the heater.
You dont have to tear down the panels to test if its good, if you have a print you can test the circuit at the control board,  the other prints for samsung models are pretty close, however I dont have your print.  Will be connector number coo7 something like that and you need to check continuity from 7-9.  Common to the other side of heater, heaters and thermal fuse, or bi metal thermostat.
Maybe some one has the print.  I'll post the request.
I'm trying to get the print, but I also think this is where you need to look, they call it a
Defrost sensor
PART NUMBER: DA32-00006S  got that off repairclinic
This is just a guess, but on the print this part is where the thermal fuse was on th LASH model
They like to play games with the names of things.  they change the name to defrost sensor, but it may be just a fuse that blows .
A bi-metal thermostat is a true sensor, it senses heat or cold and opens or closes.  it resets it's self
Sure a fuse is a senor too, sense too much heat but when it blows its over, out of game
