blewing
whirlpool refrigerator model ED22RFXFW01
2 posts in this topic
The freezer door is leaking water through a tiny hole located on the underside of the freezer door opposite the hindges that hold it on. Can you tell me what this is and how to fix it and what part to purchase? thank you so much for your help.
Sincerely
blewing1128@gmail.com
Let's first rule out a leak in your water line going to the dispenser. Either turn the water off to the fridge or lock the dispenser controls so no one can dispense water. See if the leak goes away after 4 or 5 days (give it time to leak out any residual water build up already in the door cavity). If the leak stops, pour water onto the water dispenser drip tray in order to rule out a crack in the door under the drip tray. If no water leaks out then you may have to replace the water line from spout to the bottom of the freezer door.
