pschumac
Samsung Dryer - grinding/clicking noise when spinning
5 posts in this topic
Samsung model #DV328AEW/XAA
Dryer started making this terrible grinding/clicking noise when the drum spins. I can hear it when I manually spin the drum or when I turn it on. The heating element works fine and it seems to spin okay. The belt is in place and tight enough.
Here's a short video of the noise. In the first half of the video I'm spinning the drum manually and then at the 20 second mark, I turn the dryer on.
https://www.dropbox.com/s/jmjo56ryfe...2015.37.00.mp4
Any help would be appreciated.
-Peter
Samsung,, I have a front loader (style), that has a spilt drum in the back,  shooting in the dark here, dont know if yours is a front load ( size) model.
If it is take off the top and look at the back section, roll the drum around,  if the drum is ok you probally have a bad roller, wheel, or guied.
Belt tensioners also get junk in them, on shaft, this will eventually cause a stopage of the belt.  Some are bushings :solid ...others may have bearings.
Look for hairline cracks..
Edited by curjones
The issue was that the strap from a bathing suit top had gone down through the lint filter and gotten stuck in the blower wheel.  There was a small metal clasp on the strap that was hitting the blower and causing the noise.
Thanks for the up-date.. :thumbsup:
