Cycling Thermostat tester Inspired by Durham
8 replies to this topic
#1 curjones
curjones
    Senpai
  • PipPipPipPip
  • 516 posts
  • Flavorite Brew:diet coke
Posted 22 October 2013 - 12:58 AM
I was Inspired by Durham Appliance to compete with him in the market shares of Samuriai's profit, and prophet's of wisdom income producing Gadets.
This is my version of a dryer cycling thermostat (or whatever the proper name is) test device with instant  temp feed back (+/- 10 deg).  Not going to do a lot of typing the pictures tell the story will try to put them in sequence.  May need admin help.
This has a built in high limit safety device, if you can't hold that plastic coffee can, no more (or it's melting, LOL) AND the meter has not changed  from continuity to No continuity (my  fluke meter displays ol, no continuity)  THEN YOU MIGHT HAVE A BAD CYCLING THERMOSTAT.
IF you continue to hold on to it at that point THEN YOU MIGHT BE a CHEESE-DORK (up north term)
OR
A REDNECK (down here in the south)
OH, that is a hair, blow dryer, not a heat gun, not an torch, or flame thrower.  A blow dryer set on hot air..  lol
#2 DurhamAppliance
    Sho' Nuff Chozin
  • 5,250 posts
Posted 22 October 2013 - 06:50 AM
That is cool as all get out!... if i may be so bold....
"Tired of using inaccurate heat plates? Fed up with throwing away good expensive cycling thermostats? Fear no more. Cur has the cure! Introducing...... Cur's Super Cycling Saver! "
well that's the best my marketing dept can do on short notice and before my, I mean their, morning coffee.
For innovation, usefulness, humour and coolness you receive 4 of the newly designated Durham's Coveted Kip Awards :
www.DurhamApplianceThrift.com
#3 curjones
curjones
    Senpai
  • PipPipPipPip
  • 516 posts
Posted 22 October 2013 - 10:32 PM
Got my clips today to make your thermister tester, thanks for the Kip awards,
Curtis,
#4 curjones
curjones
    Senpai
  • PipPipPipPip
  • 516 posts
Posted 25 October 2013 - 09:43 PM
Update,  I tested some older cyclers and my temp gauge got to 180 degrees, but it did not cycle off,  used the put it on the griddle method and they did cycle off, but I have no idea what temp the griddle was,  about 200 degrees I'm guessing.  A new cycling them will cut out in this test tube baby of mine.
There may be an issue of heat transfering to the thermometer faster than the surface of the cycling therm.  may need to use a metal can for the back.
I sent out a dryer with a bad, never would shut off cycle therm, so thats why I wanted to make a tester, I also have a place that has some used parts and want a fast, handy way to test several in a hurry.  With out cooking pancakes and sausage in the process..
#5 DurhamAppliance
    Sho' Nuff Chozin
  • 5,250 posts
Posted 26 October 2013 - 11:35 AM
yeah, we run our dryers and look and listen for the cycling before selling them but having a tester for onsite repairs as well the ability to test and keep cycling therms from scrapped dryers is invaluable.
I think you are on to something regarding the metal can. Maybe even a soda can (insulated so as to not burn your hand) and heat gun?
#6 curjones
curjones
    Senpai
  • PipPipPipPip
  • 516 posts
Posted 28 October 2013 - 12:31 AM
Yeah, had that in my mind about insulating the can, may have to throw in one welders glove in the PPE list of require equipment list.  may have to include it in the kit set.  Price will have to go up from. 39.95 to 59.99, when we get it to market.  Lol
#7 tonytech81
tonytech81
    Ikkō-ikki
  • Appliantologist
  • 50 posts
  • Flavorite Brew:Bud Lime @ cold Tea
Posted 17 January 2014 - 11:50 PM
Bro that a kook tool salvage baby that how we do it
#8 -Mike-
-Mike-
    Kohai
  • 338 posts
  • Flavorite Brew:diet Pepsi
Posted 19 January 2014 - 02:08 AM
I have the perfect answer for you....
images?q=tbn:ANd9GcSLy06mv18iIqVQb-zWEl2
It won't be damaged by heat
You can hold the handle to keep from burning your hand
It looks like a high tech tool that will impress your customer
Its stainless steel that will hold up to lots of use of abuse. The ultimate in long term durability.
#9 Applianceman97
Applianceman97
    Baby Sensei
  • 2,199 posts
Posted 24 January 2014 - 02:14 AM
That's cool!
