Troubleshooting and Repairing the F11 Error Code in a Whirlpool Duet Washer
Whirlpool washer Duet F11 error code CCU MCU wiring harness Kenmore
3 replies to this topic
#1 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 30,057 posts
Posted 23 October 2013 - 07:40 AM
Join The Appliance Guru on a safari deep into the silicon bowels of a Whirlpool Duet front loading washer, tracking down the elusive and mysterious F11 error code.
If you live in the Kearsarge-Lake Sunapee Region of New Hampshire, call The Appliance Guru for expert appliance repair service:  http://ApplianceGuru.com
#2 santacruzappliance
santacruzappliance
    Ikkō-ikki
  • Appliantologist
  • 44 posts
  • Flavorite Brew:Sculpin IPA
Posted 31 December 2014 - 09:05 PM
I'm curious to know if you would ever need to add solder to the MCU?  How do you determine which area is lacking a solid connection?
    Shōgun
  • 30,057 posts
Posted 01 January 2015 - 09:53 AM
Sometimes you can tell visually or by how snug the edge connector feels. You may note be able to tell and may need to add solder to both the CCU and MCU IF you're really dealing with a communications error.
The question you need to answer during your diagnosis is this: Am I really just dealing with an intermittent communications error or a bad MCU?
Keep in mind that, depending on how it fails, a bad MCU can also cause the CCU to throw and F11 error code. The MCU may not be sending a handshake signal back to the CCU so the CCU algorithm would flag that as an F11 error code.
#4 santacruzappliance
santacruzappliance
    Ikkō-ikki
  • Appliantologist
  • 44 posts
Posted 03 January 2015 - 02:22 PM
Thanks Samurai!
Also tagged with one or more of these keywords: Whirlpool, washer, Duet, F11, error code, CCU, MCU, wiring harness, Kenmore
