Sign in to follow this
Followers 0
heappliances
790.42003603 - Kenmore Convection Oven keeps beeping.
5 posts in this topic
Good Morning/Afternoon Gurus.
We have a Kenmore Convection Oven Model #790.42003603.
Top oven on Bake selection keeps consistently beeping when heating up/ going to selected temperature.
I can hear relay clicking like it is trying on and off heating element.
As soon it is reaching desired temperature it stops.
As soon as temperature is going down, it starts consistently beeping again in a sequence of short beep (temperature selection), long beep (desired temperature reached) and supporting by relay clicking sound with each beep (short and long). No Error Codes displaying.
For me, looks like relay responsible for turning on/of bake heating element in top oven is failing on the board.
However, this dude has 5 boards:
316460300 - excluding, as it looks like it is a use interface board (Control Panel Diagram)
316435701 - excluding, as it looks like it is a power board (Control Panel Diagram)
316460201 - (Control Panel Diagram)
316443910 - (Upper Oven Diagram)
316460901 - (Upper Oven Diagram)
 Any suggestions which board is causing this behavior? I am leaning toward main board  316460901, but need your highly experienced opinion.
Thank you!!!
I don't know the answer right now... will have to think about it ..
but, it may be a bad Oven Sensor
Could try swapping the upper and lower Oven Sensors
http://appliantology.org/files/file/1333-kenmore-oven-79042003603-parts-tech/
Kenmore Oven
by Frigidaire
790.42003603
5995491031 parts & wiring
318204800 service data
318271935 wiring
after upload approval by the Samurai
i have not seen that happen with a failed sensor. Sounds like the board's brain is scrambled. Bro Reg's suggestion is a good one to eliminate sensor as the culprit .
I think Reg might be right.  There was a service bulletin on the 30' Frigidaire freestanding ranges addressing a beeping sound from the control section with no fault codes displayed.  The culprit was the mini oven sensor being open or shorted, as well as an over temp issue.  I'll keep checking.
Thank you all for a great suggestions.
We are checking if the issue is resolved.
This is what we did:
1. replaced relay board - initial beeping eliminated during pre-heat. As soon as it pre-heated and temp going down, long - short beeps are continues.
2. exchanged heat sensors between lower and top. (did not installed new) - issue is completely resolved. Both units are working normally without beeping. (mystery) However, when running both ovens and turning them completely off, got "Err" displayed. No number, just "Err". It happened only 1 time and we cannot re-produce it again. Will be checking with a customer after a while.
Followers 0
