GE Monogram woes. Freezer working too hard, fridge not hard enough.
35 replies to this topic
#1 mada
mada
    Yamabushi
  • 75 posts
Posted 26 October 2013 - 08:12 AM
(serial# ZISS420NRESS) GE Monogram has had this problem before:
Freezer is at -17 and fridge is at 44 degrees.
Last time this happened, I took everything out of it and let it thaw for a few days. Plugged it back it and ran perfect for about a month.
Now, i've decided that I don't wan to have to do this everytime and I'd like to address the main problem.
Can anyone advise what's wrong and what parts to buy for the fix?
Thank you!
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 26 October 2013 - 10:54 AM
check to see if the Evaporator Coils in the Freezer are overly frosted / air clogged / (Defrost problem)
#3 mada
mada
    Yamabushi
  • 75 posts
Posted 26 October 2013 - 02:24 PM
thank you. are they visible, or do I need to take anything apart to see them. Sorry, I'm pretty much a rookie (but ready to dive in)
#4 PDuff
PDuff
  • 2,011 posts
Posted 26 October 2013 - 02:50 PM
I expect a faulty evaporator sensor P/N WR55X10025, possibly along with a blocked defrost drain.  Unit will have to pulled from cabinet and accessed from the upper unit section.
#5 mada
mada
    Yamabushi
  • 75 posts
Posted 27 October 2013 - 09:30 AM
How do I check this? Thanks so much -- I'll put one big order together to buy everything I need for this repair. Just want to make sure I have a good plan before going in to fix the issue.
#6 mada
mada
    Yamabushi
  • 75 posts
Posted 28 October 2013 - 07:46 AM
thank you. I will replace this no matter what, looks inexpensive enough... can you tell me where it is? Also, do you know how and where to check the evaporator coils so I can see if they are overly frosted? RegUS_PatOff   Had suggested I check this too, but not sure where they are. Thanks!
#7 RegUS_PatOff
  • 33,588 posts
Posted 28 October 2013 - 07:57 AM
Evaporator # 800
Evaporator Sensor # 336
#8 mada
mada
    Yamabushi
  • 75 posts
Posted 28 October 2013 - 10:07 AM
Ah, nice. So that is behind the ice maker?
Evaporator # 800
#9 RegUS_PatOff
  • 33,588 posts
Posted 28 October 2013 - 11:40 AM
yes
http://appliantology...is-420-zis-480/
GE Fridge 31-9117
ZIS360NR
ZIS420NR
ZIS480NR
ZIS_360DR
ZIS_420DR
ZIS_480DR
ZISS360DR
ZISS420DR
ZISS480DR
#10 mada
mada
    Yamabushi
  • 75 posts
Posted 28 October 2013 - 12:12 PM
Ok got to em'  -- no frost there, looks pretty frost free actually. Any other ideas to what it could be. It's now -8 degrees in the freezer and 40 in the fridge.
#11 RegUS_PatOff
  • 33,588 posts
Posted 28 October 2013 - 12:20 PM
Is the Evaporator Fan in the Freezer, working at full speed ?
(when the Compressor is running)
#12 mada
mada
    Yamabushi
  • 75 posts
Posted 28 October 2013 - 06:33 PM
yes, running as it always has. Strange thing was that when I checked the coils they were bare copper & pretty much was hot to the touch. Just now they have a thin layer of frost.
#13 mada
mada
    Yamabushi
  • 75 posts
Posted 29 October 2013 - 06:48 AM
Update: this morning opened it up and saw the freezer at -16 and the fridge at 42.
#14 mada
mada
    Yamabushi
  • 75 posts
Posted 29 October 2013 - 11:39 AM
also, I should say, that I don't mind being agressive on replacement parts, this fridge has one more chance to prove itself useful before I turn it into scrap metal.
#15 mada
mada
    Yamabushi
  • 75 posts
Posted 29 October 2013 - 07:10 PM
finally used the flowchart! Takes me right to "check or replace the air damper assembly" Can someone sort me to parts so I can purchase. I'm happy to buy them from a location that benefits this site!
#16 Samurai Appliance Repair Man
    Shōgun
  • Master Samurai Tech
  • 29,813 posts
Posted 29 October 2013 - 07:44 PM
Nice work!
Damper assembly:  http://www.repaircli...9X10107/1092760
#17 mada
mada
    Yamabushi
  • 75 posts
Posted 30 October 2013 - 07:32 AM
awesome. I'll buy today. Can you tell me if this comes with the styrafoam housing? I think I cracked and fixed mine too many times in the past. I'd like to buy a new one of those too. Also, should I replace any other of the susspect parts for good measure?
#18 MicaBay
MicaBay
    Master Roaster
  • PipPipPipPip
  • 829 posts
  • Flavorite Brew:Drifter Pale Ale
Posted 30 October 2013 - 07:54 AM
Any of the thermistors that have a black colored silcone where the wires enter the little body.  If it is solid white, no need to replace without proper check.
#19 mada
mada
    Yamabushi
  • 75 posts
Posted 30 October 2013 - 01:14 PM
cool, how about the styrafoam housing? Does that need to be purchased seperately?
#20 RegUS_PatOff
  • 33,588 posts
Posted 30 October 2013 - 01:28 PM
I believe # 368 is included with # 367 kit
