Affinity keeps shutting off
8 replies to this topic
#1 bkm564
bkm564
  • 4 posts
Posted 29 October 2013 - 10:15 AM
I have a Frigidaire Affinity model ATF8000FE1 front load washer. When we start it, it whines for a bit, normal sound it makes, then shuts off and flashes error. I can pull on the door slightly and a small amount of water will pump in before it shuts off. Any help will be appreciated.
       Brian
#2 RegUS_PatOff
  • Academy Instructor
  • 33,588 posts
Posted 29 October 2013 - 12:49 PM
which error ?
#3 bkm564
bkm564
  • 4 posts
Posted 29 October 2013 - 01:29 PM
it just says err
#4 RegUS_PatOff
  • 33,588 posts
Posted 29 October 2013 - 02:24 PM
READING ERROR CODES:
1. Wake the washer by pressing any button.
2. Wait 5 seconds.
3. Press and HOLD the Start/Pause and Cancel buttons simultaneously.
As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers,
a number and a letter or two letters.
The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash.
#5 bkm564
bkm564
  • 4 posts
Posted 29 October 2013 - 03:00 PM
E23
#6 RegUS_PatOff
  • 33,588 posts
Posted 29 October 2013 - 03:13 PM
something wrong with the Drain Pump / circuit
E23 Drain pump relay on control board failed or wire off pump.
Replace control board or wire.
#7 bkm564
bkm564
  • 4 posts
Posted 29 October 2013 - 03:30 PM
Thank you
#8 sh2sh2
sh2sh2
    Senpai
  • PipPipPipPip
  • 775 posts
  • Flavorite Brew:yeunling
Posted 29 October 2013 - 06:05 PM
check drain pump   I have found bad pumps cause this code, motor windings would read no continuity.
    Shōgun
  • Master Samurai Tech
  • 30,385 posts
Posted 29 October 2013 - 07:37 PM
Part links:
Main control board:  http://www.repaircli...7007000/1469146
Drain pump:  http://www.repaircli...7221600/2754548
