Frigidaire gas oven FGF380MXDCA cannot get oven access panel off
7 replies to this topic
#1 Ritz
Ritz
    Senpai
  • Chief Appliantologist
  • PipPipPipPip
  • 556 posts
Posted 29 October 2013 - 12:13 PM
I've done a few hundred of these repairs. Oven won't light. Needs new oven igniter.
However after I take the two back hand screws out, this one need to remove the convection fan cover, then lift panel out. Not with this dude. I spent and hour tryi g to get it off. The clips in the front will not work with me. Hope there is help?
Thanks for any advice.
#2 PDuff
PDuff
  • 2,066 posts
Posted 29 October 2013 - 12:52 PM
Chassis and liner front might be flexed.  Try pulling unit from cabinet to be sure it's level then try removing liner floor.
#3 Budget Appliance Repair
  • Senior Appliantology Fellow
  • 5,036 posts
Posted 30 October 2013 - 06:09 AM
I had one of these once that I had to replace the oven floor because it was rotted thru from acidic spills.
Nothing I did would make it come out in a normal manner, since it was already bad and was going to be replaced, I bent it and used tin snips to cut it out.
New one went right in if I remember correctly, so I don't know what was making it  so difficult to remove.
I know this doesn't really help you but just letting you know your not the only one to ever have a problem with one of those.
William Burk (Willie)
Eureka, CA 95501
#4 Ritz
Ritz
    Senpai
  • PipPipPipPip
  • 556 posts
Posted 30 October 2013 - 07:01 AM
Thanks for your reply. Cutting it out must have been tough. That's the only solution I can think of.
I actually had the same oven call that day and took a video of me removing the floor (very easily of course) and emailed it to the customer so they didn't think I was incompetent!
#5 Budget Appliance Repair
  • 5,036 posts
Posted 31 October 2013 - 05:29 AM
Actually it wasn't that tough to cut it since large holes were already rotted thru which gave me a place to start cutting with tin snips and the metal wasn't all that tough to cut through.
Eureka, CA 95501
#6 Ritz
Ritz
    Senpai
  • PipPipPipPip
  • 556 posts
Posted 31 October 2013 - 05:38 AM
Update: were going to cut the floor up to remove it. I've ordered a new floor.
I think in going to cut it up with my Dremmel to get it out. Should be nice a nice a quiet proceedure!
Thanks!
    Shōgun
  • Master Samurai Tech
  • 30,624 posts
Posted 31 October 2013 - 08:02 AM
Take some pics or, better yet, video!  Would love to see this.
#8 Ritz
Ritz
    Senpai
  • PipPipPipPip
  • 556 posts
Posted 31 October 2013 - 09:24 AM
you got it
