Bosch Dishwasher model SHE46C05Uc/22 leaks
1 reply to this topic
#1 mfred
mfred
  • 2 posts
Posted 30 October 2013 - 06:57 AM
The dishwasher leaks from a vent hole in the top of a plastic chamber (that contains the float switch) when filling. I don't see any obstructions in the lines. It seems as if the water comes in the chamber faster than it can go out.
#2 PDuff
PDuff
  • 2,017 posts
Posted 30 October 2013 - 12:10 PM
Water fill assy's on Bosch dishwashers can be a pressure fill (with diaphragm), or time fill, depending on model.  Your model uses the time fill assy.
Most water fill assy repairs involve replacing microswitches.  Occasionally tank insulation or other debris can prevent the diaphragm switch lever from operating, allowing overfilling.  This is not the case with your model, although debris could still an issue.
Water inlet valves for time and pressure fill assy's look the same, but pressure fill valves can't be used on time fill models.  Presently, both pressure fill and time fill models use the time fill valve: http://www.repaircli...0425458/1105846
Floats should be checked and bases should be cleared of water and debris whenever water fill assy's are worked on.
If needed, replacement water fill assy for your model:  http://www.repaircli...0440670/1106268
Edited by Samurai Appliance Repair Man, 30 October 2013 - 01:43 PM.
Added part links.
