dutchbrian
Rinse/Spin problem with GE WBSR3140DOWW
39 posts in this topic
Hi
We have the GE WBSR3140 and the rinse and spin cycle only works when the washer is empty. It does not function on a normal wash cycle. The water just stays in the drum and the control timer just clicks round.
I have removed the front, removed the control panel and checked all connections, hoses and the pump. Everything looks OK. I think it is a sensor fault but I no idea what it could be or what part might be the problem or how to repair it.
We live in The Netherlands but is a US machine so would need to order any parts.
Can anyone help to got any ideas how to correct the problem?
  Not sure I understand the symptoms. Does it agitate at all? Won't drain in normal cycle but will in other cycles? If timer is running, the sensor (pressure switch) is working. Sounding like a timer problem (bad contacts) but need more info on the symptoms. Can you post photo of the wiring diagram? Should be folded up behind control panel. I have similar version but not exact one you have.
Eric
Hi Eric,
IF you run a normal wash programme, the water fills and the agitator works ok but the water does not drain nor does rinse or spin work. The timer then continues round and just keeps going. In fact we actually let it run overnight and it did not stop!!
If you remove the water and cloths and then run the rinse and spin option of quick wash programme, the water fills and the spin works. If you run the same rinse and spin programme with the water still in the drum, there is no agitation working and as the timer is moving, you can hear clicking sounds as it appears to go through different programme steps. Do you have an e-mail address as the photos of the wiring diagram is too big to send with this reply
Brian
  So, basically, the pump never works? Washer must drain in order for it to go into spin. If it stays full of water, timer will continue endlessly. Since you only have "grasshopper" status, I can't PM you my email address and you can't post photo's. Either post the photo to a website such as Photobucket and provide link here or upgrade to apprentice ($10) and we can send private messages.
Eric
If you run the rinse and spin on the quick programme, it will spin if there is no water in the drum. I dismantled the pump and it appears to be working fine. I also checked the hoses. The problem must be to do with detecting the water level and then entering the rinse/spin cycle. Your description of the timer continuing when it does not drain is exactly what happens.
  Does the washer drain after agitation????
No, it just agitates
  After agitation stops, you need to check for power at the pump terminals. Either the pump is faulty, or it's not getting power through the timer contacts.
  How are you powering the washer? Isn't power there 220vac?
I think the pump is ok because it is impossible to remove manually all the water from the drum but the pump functions ok to remove the remaining  residual water on the rinse/spin programme when the drum is empty. Maybe it is the timer control.
power is 220v but we use a step down transformer (1000w) to 110v.
How would I check the voltage at the pump? I have a meter
  Set the meter to read ac voltage. After agitation stops, place meter probes into back of connectors at the pump. Make sure probe tips are touching the metal part of the wire terminals inside the plastic covers. There may be a short period of time between when agitation stops and draining should begin. Shouldn't be more than a minute. If the timer just continues around and you never get power to the pump, then the timer is faulty. If you get power but pump doesn't run, then the pump is faulty or something is jamming it.
Eric
I will run the test this weekend and let you know. My wife is flying to the States next weekend so we can arrange to send any new parts to our friends address in Oregon .
Brian
Hi Eric,
I have run a number of tests with my multimeter on the pump as suggested.
I ran the Delicates programme. Water entered the drum and the drum was agitated. No voltage at pump during agitation phase of programme. When the agitation stopped, the pump voltage rose to 114-117v but there was no drainage, rinse or spin during rest of cycle. The timer automatically moved to next programme.
Ran rinse & spin programme from Easy Care with water still in drum.  Voltage stayed at 114-117v but there as no drain, rinse or spin.
I emptied the drum using wet/dry vacuum and ran rinse & spin Easy Cares programme. Water enters at start with pump voltage  0v is zero. No agitation took place. 20% into programme pump voltage rose to 116v but no spin. Timer clicking.
I emptied the drum leaving 2 inches water in drum. Ran last 50% part of rinse & spin Easy Care programme.
Pump voltage drops to 103v with 1-2 secs agitation, tries to drain and spin with pump voltage rising to 115v. Towards end of programme (last 15%)  pump voltage drops to zero.
I removed the last two inches of water and ran second half of rinse & spin EasyCare programme. Some water (two inches) added. During 1-2 secs agitation pump voltage drops to 104. When agitation stops, pump voltage rises to 115v. There is a slight smell of overheating and pump is warm/hot to touch. Shortly before end of programme, pump voltage drops to zero.
I ran the last 15% of rinse and spin EayCare programme. There was a  longer period of agitation (15-30 sec) of the residual water (between drum and outer drum casing) pump voltage mainly around 115v but fluctuates from. 99-140v There was no drain or spin.
I hope that helps. It seems it could be the pump or perhaps the sensor that detects there is water in the drum.
Brian
Hi
Could the fact that the machine was unused  stored in the house, for about 2 years be the reason for the pump failure? It was in working order when we bought it. I have actually dismantled the pump itself and the impeller moves freely.  I could not feel any hose blockages when I dismantled the pump. I guess perhaps the pump electronics may have got damaged when we transported from the seller to us.
Brian
If you have the pump out, hook it up to 110 volts direct and see if it runs.. Or check continuity with your ohm meter.  Sounds like a pump problem!
What is the voltage coming out of this step down transformer? While under load and sitting idle?
Could the polarity be reversed coming into the machine? Jus t check to make sure that neutral and cabinet ground are in the right place and get back to us. Lets rule out the  stupid stuff first.
I will try and answer the questions.
Polarity looks ok, grounding looks ok.
voltage coming out of transformer (idle) is 115v. Not sure how to test under load?
put multimeter across pump in situ, machine powered up but idle, gave a read of 12ohm. Pump is rated at 120v, 85W, 60Hz.
Hope that helps.
what do you mean machine powered up? Did you hook the pump up with a jumper to see if it runs.  So far as I can see the pump has never run.  Try hooking it up direct.
Machine is plugged into a 110v step down transformer (we are on 220v in The Netherlands) as if we were about to use for washing. Are you suggesting to take output from transformer directly to the pump? I am not sure I have the means to do that. Can I just construct some cables?
In all the time we have been trying to get it to work during the last week, I think the pump has only worked as it should twice.
Brian
Some further info...
My wife reminded me that when the machine was first switched on we used a 110v 100W step down transformer which started smoking. We then used the 110v 1000W and it seems to work fine. Could the pump have been damaged by using the wrong transformer?
Brian
Brian
yes, rig up a plug to a cable and plug it into the transformer, then connect it to the pump.  I just want to see if the pump works as it should.  If not then we know you need a pump.  If the pump is ok, then we can look elsewhere for the problem.
"when the agitation stopped, the pump voltage rose to 114-117v but there was no drainage"
  There was good voltage to the pump but no drainage. Pump is bad or pump/hoses blocked. No need to fashion a cheater cord to test pump.
Eric
